Is there any way to add the Zorin menu on the second taskbar when using dual monitors? For the life of me I can't find any way to do this.
Are you using Zorin OS Core or Lite?
On Zorin OS Lite; it is very easy. On Core, it is not so easy and I am not sure if it is possible.
On my build I have Zorin Menu on one monitor and WhiskerMenu on my Primary Monitor.
Ah sorry, forgot to say. I'm using Pro.
