My monitors are both recognized by the system, however when I go to display settings the maximum resolution option shown is 2560 x 1440 and I am unable to select 4K resolution. Is there a way I can get it to recognize that the monitor supports 4K?
I am using a KVM matrix which has my monitors, keyboard, and mouse plugged in.
The xrandr output is:
Screen 0: minimum 8 x 8, current 5120 x 1440, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 621mm x 341mm
2560x1440 59.95*+
1920x1080 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1280x720 60.00 59.94 50.00
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 621mm x 341mm
2560x1440 59.95*+
1680x1050 59.95
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 60.02
1280x960 60.00
1280x800 59.81
1024x768 60.00
800x600 60.32 56.25
720x576 50.00
720x480 59.94
640x480 59.94 59.93
It allows you to connect multiple computers to one set of monitors, keyboard, and mouse and then swap back and forth. It is a 4K model and I am able to get full 4K resolution in Windows so it isn't a direct limitation of that.
Ok - I initially moved the cables from the KVM direct to the computer, which didn't work - however they were DisplayPort to HDMI since the KVM doesn't support DP. I tried again with plain DP cables, and now it's able to set to 4K.
I can do without the KVM at least for now, hopefully I can find some way to make it work through that.
Okay, at least a Workaround for now. Did You checked the Manufacturers Website if there are maybe Instructions for Linux or an offered Driver for better Support?
I had a feeling it was a cable issue. I have gone through this myself. I bought a displayport cable that looked decent, it was even fiber wrapped nicely. However, when I went to use it, it wouldn't transfer anything to my Dell 4K monitor. I was forced to buy another cable, and that was it, different brand of cable, unfortunately not fiber wrapped, but it worked!
I never had these problems with older cable standards and older monitors, this only recently became a thing. I think it has everything to do with how cables are made, not all of them actually meet specification.
