Hello,
Sometimes when I shutdown my PC, it stays on the shut down screen (the zorin logo glowing). And when I press F12 to see what is happening the last thing that is going on is "Running a stop job for Portmaster 5s/...) (it counts up). And it takes really long to shutdown or it just doesn't shutdown at all. I use portmaster to monitor my firewall and controlling certain applications so I don't want to uninstall it.
I searched the internet for answers but nobody seems to have the same problem with portmaster?
If I understand it correctly a stop job is to stop a program that is being active in the background. Is that correct?
I'm using the latest version of ZorinOS Core (17).
I just did a websearch "portmaster holding shutdown ubuntu" and found several issues of portmaster affecting shutdown e.g.
opened 07:12PM - 18 Sep 20 UTC
closed 09:18AM - 29 Sep 20 UTC
bug
**Checklist**:
- [X] I'm using the official portmaster release (i.e no custom… builds)
- [X] I searched for similar/existing issues first.
- [X] My issue is not mentioned in the Known Issues section of my [OS](https://github.com/safing/portmaster/wiki)
**What happened**:
I tried to turn portmaster off by system-monitor or shutdown it through the UI. I pressed on shutdown in the UI and it said that I should reboot to fully work but after pressing ok, on the bottom left the status says "Not connected to Core!" (new line) "Retrying..." and after a bit it is activated again and it continues to protect me (which i don't want for now). After rebooting nothing happens except portmaster automaticly is running and protecting me. If I close the process in the system-monitor then I have no internet anymore which I also don't want.
**What you expected to happen**:
I expected to use the internet as I usually do without protection.
**How to reproduce it (as minimally and precisely as possible)**:
Install Portmaster.deb on Pop!_os 20.04, reboot, try to shut it down over UI or end it through system-monitor.
**Anything else we need to know?**:
There is no simple function to disable it for a minute (which would be useful if you just want to try to connect your virtual machine (virt-manager) with internet or any other program that for some reasons don't work. Can't even find it in the app settings nor monitor)
**Environment**:
Portmaster Version:
Version: 0.5.4
Commit: tags/v0.5.4-0-g6093c5b8476e488b63d3a735b2ad178b7625114b
Build Options: main.go
Build User: user
Build Host: docker
Build Date: 19.08.2020
Build Source: https://github.com/safing/portmaster
Operating System:
- [ ] Windows 7
- [ ] Windows 8/8.1
- [ ] Windows 10
- [x] Linux
NAME="Pop!_OS"
VERSION="20.04 LTS"
ID=pop
ID_LIKE="ubuntu debian"
PRETTY_NAME="Pop!_OS 20.04 LTS"
VERSION_ID="20.04"
HOME_URL="https://pop.system76.com"
SUPPORT_URL="https://support.system76.com"
BUG_REPORT_URL="https://github.com/pop-os/pop/issues"
PRIVACY_POLICY_URL="https://system76.com/privacy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
LOGO=distributor-logo-pop-os
If applicable you can provide related sections from the log files and ensure to **remove sensitive or otherwise private information**.
- Linux: `/var/lib/portmaster/logs`
Logname: 2020-09-18-18-28-15.log
NJ{"Created":1600453695,"Modified":1600453695,"Expires":1603045695,"Deleted":0}S
executing core/portmaster-core version 0.5.4 on linux amd64
[34m200918 20:28:15.835 ▶ BOF[0m
[34m200918 20:28:15.835 ules/start:089 ▶ INFO 001[0m modules: initiating...
[31m200918 20:28:15.835 e/asm_amd6:1373 ▶ ERRO 002[0m modules: tasks should only be started when the module is online or starting
[34m200918 20:28:15.835 ules/start:186 ▶ INFO 003[0m modules: started database
[34m200918 20:28:15.836 ules/start:186 ▶ INFO 004[0m modules: started config
[34m200918 20:28:15.837 ules/start:186 ▶ INFO 005[0m modules: started rng
[34m200918 20:28:15.837 ules/start:186 ▶ INFO 006[0m modules: started base
[34m200918 20:28:15.837 ules/start:186 ▶ INFO 007[0m modules: started subsystems
[34m200918 20:28:15.837 ules/start:098 ▶ INFO 008[0m modules: initiated subsystems manager
[34m200918 20:28:15.938 dules/mgmt:070 ▶ INFO 009[0m modules: managing changes
[34m200918 20:28:15.938 ules/start:186 ▶ INFO 010[0m modules: started api
[34m200918 20:28:15.938 api/router:062 ▶ INFO 011[0m api: starting to listen on 127.0.0.1:817
[34m200918 20:28:15.938 ules/start:186 ▶ INFO 012[0m modules: started netenv
[34m200918 20:28:15.938 ules/start:186 ▶ INFO 013[0m modules: started notifications
[34m200918 20:28:15.949 ules/start:186 ▶ INFO 014[0m modules: started status
[33m200918 20:28:15.953 ment_linux:144 ▶ WARN 015[0m environment: could not get nameservers from dbus: No such interface “org.freedesktop.DBus.Properties” on object at path /
[34m200918 20:28:15.953 /resolvers:248 ▶ INFO 016[0m resolver: no local resolvers loaded
[34m200918 20:28:15.953 /resolvers:258 ▶ INFO 017[0m resolver: no system/network-assigned resolvers loaded
[34m200918 20:28:15.953 /resolvers:272 ▶ INFO 018[0m resolver: no scopes loaded
[34m200918 20:28:15.953 ules/start:186 ▶ INFO 019[0m modules: started resolver
[34m200918 20:28:15.967 ules/start:186 ▶ INFO 020[0m modules: started updates
[34m200918 20:28:15.967 ules/start:186 ▶ INFO 021[0m modules: started geoip
[34m200918 20:28:15.967 ules/start:186 ▶ INFO 022[0m modules: started ui
[34m200918 20:28:15.971 ine-status:194 ▶ INFO 023[0m netenv: setting online status to Online (all checks passed)
[34m200918 20:28:15.984 ules/start:186 ▶ INFO 024[0m modules: started profiles
[34m200918 20:28:15.984 ules/start:186 ▶ INFO 025[0m modules: started processes
[34m200918 20:28:15.984 ules/start:186 ▶ INFO 026[0m modules: started network
[34m200918 20:28:16.065 ules/start:186 ▶ INFO 027[0m modules: started filterlists
[34m200918 20:28:16.065 ules/start:186 ▶ INFO 028[0m modules: started intel
[34m200918 20:28:16.084 ules/start:186 ▶ INFO 029[0m modules: started interception
[34m200918 20:28:16.084 ules/start:186 ▶ INFO 030[0m modules: started core
[34m200918 20:28:16.084 ules/start:186 ▶ INFO 031[0m modules: started filter
[34m200918 20:28:16.084 ules/start:186 ▶ INFO 032[0m modules: started nameserver
[34m200918 20:28:16.084 dules/mgmt:088 ▶ INFO 033[0m modules: finished managing
[34m200918 20:28:16.100 les/worker:100 ▶ INFO 034[0m nameserver: service-worker dns resolver requested restart: stopped conflicting name service with pid 9496 - restarting now
[34m200918 20:28:16.115 connection:207 ▶ INFO 035[0m filter: granting connection libvirt-dnsmasq:/usr/sbin/dnsmasq:1441 <- 127.0.0.53, endpoint in allowlist: scope matches Localhost
[34m200918 20:28:16.468 d-response:051 ▶ INFO 036[0m api request: 127.0.0.1:50722 HIJ /api/database/v1
[34m200918 20:28:16.468 i/database:084 ▶ INFO 037[0m api request: init websocket 127.0.0.1:50722 /api/database/v1
[34m200918 20:28:16.469 d-response:051 ▶ INFO 038[0m api request: 127.0.0.1:50720 HIJ /api/database/v1
[34m200918 20:28:16.469 i/database:084 ▶ INFO 039[0m api request: init websocket 127.0.0.1:50720 /api/database/v1
[34m200918 20:28:16.484 d-response:051 ▶ INFO 040[0m api request: 127.0.0.1:50726 HIJ /api/database/v1
[34m200918 20:28:16.484 i/database:084 ▶ INFO 041[0m api request: init websocket 127.0.0.1:50726 /api/database/v1
[34m200918 20:28:16.484 d-response:051 ▶ INFO 042[0m api request: 127.0.0.1:50728 HIJ /api/database/v1
[34m200918 20:28:16.484 i/database:084 ▶ INFO 043[0m api request: init websocket 127.0.0.1:50728 /api/database/v1
[34m200918 20:28:16.490 d-response:051 ▶ INFO 044[0m api request: 127.0.0.1:50732 HIJ /api/database/v1
[34m200918 20:28:16.490 d-response:051 ▶ INFO 045[0m api request: 127.0.0.1:50730 HIJ /api/database/v1
[34m200918 20:28:16.490 i/database:084 ▶ INFO 046[0m api request: init websocket 127.0.0.1:50732 /api/database/v1
[34m200918 20:28:16.490 i/database:084 ▶ INFO 047[0m api request: init websocket 127.0.0.1:50730 /api/database/v1
[34m200918 20:28:19.121 all/master:084 ▶ INFO 048[0m filter: granting own connection root:/var/lib/portmaster/updates/linux_amd64/core/portmaster-core_v0-5-4:9562 <- 192.168.2.127
[33m200918 20:28:22.032 tel/entity:170 ▶ WARN 049[0m intel: failed to resolve IP 192.168.2.104: failed to resolve 104.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
[34m200918 20:28:22.041 connection:235 ▶ INFO 050[0m filter: dropping connection Unknown::-1 <- 192.168.2.104, endpoint is not allowed (incoming is always default=block)
[34m200918 20:28:25.952 all/master:084 ▶ INFO 051 [2x][0m filter: granting own connection root:/var/lib/portmaster/updates/linux_amd64/core/portmaster-core_v0-5-4:9562 to updates.safing.io. (<nil>)
[34m200918 20:28:25.957 all/master:084 ▶ INFO 052[0m filter: granting own connection root:/var/lib/portmaster/updates/linux_amd64/core/portmaster-core_v0-5-4:9562 to updates.safing.io. (116.203.130.137)
[34m200918 20:28:26.092 r/updating:077 ▶ INFO 053[0m updates: updated index stable.json
[34m200918 20:28:26.110 r/updating:077 ▶ INFO 054[0m updates: updated index beta.json
[34m200918 20:28:26.128 r/updating:077 ▶ INFO 055[0m updates: updated index all/intel/intel.json
[34m200918 20:28:26.128 r/updating:108 ▶ INFO 056[0m updates: everything up to date
[34m200918 20:28:26.143 s/upgrader:200 ▶ INFO 057[0m updates: upgraded /var/lib/portmaster/portmaster-start
[33m200918 20:28:28.033 tel/entity:170 ▶ WARN 058[0m intel: failed to resolve IP 192.168.2.104: failed to resolve 104.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
unimportant content in-between
[33m200918 20:28:41.797 ore/events:037 ▶ WARN 117[0m core: user requested shutdown
[33m200918 20:28:41.797 dules/stop:043 ▶ WARN 118[0m modules: starting shutdown...
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 119[0m modules: stopped filter
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 120[0m modules: stopped intel
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 121[0m modules: stopped geoip
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 122[0m modules: stopped nameserver
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 123[0m modules: stopped filterlists
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 124[0m modules: stopped core
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 125[0m modules: stopped notifications
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 126[0m modules: stopped subsystems
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 127[0m modules: stopped ui
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 128[0m modules: stopped status
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 129[0m modules: stopped resolver
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 130[0m modules: stopped netenv
[34m200918 20:28:41.797 dules/stop:098 ▶ INFO 131[0m modules: stopped api
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 132[0m modules: stopped interception
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 133[0m modules: stopped network
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 134[0m modules: stopped processes
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 135[0m modules: stopped profiles
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 136[0m modules: stopped updates
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 137[0m modules: stopped base
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 138[0m modules: stopped config
[34m200918 20:28:41.844 dules/stop:098 ▶ INFO 139[0m modules: stopped database
[34m200918 20:28:41.856 dules/stop:098 ▶ INFO 140[0m modules: stopped rng
[34m200918 20:28:41.856 dules/stop:052 ▶ INFO 141[0m modules: shutdown completed
[34m200918 20:28:41.866 ◀ EOF[0m
Next Logname: 2020-09-18-18-28-52.log
NJ{"Created":1600453732,"Modified":1600453732,"Expires":1603045732,"Deleted":0}S
[34m200918 20:28:52.329 ▶ BOF[0m
[34m200918 20:28:52.329 ules/start:089 ▶ INFO 001[0m modules: initiating...
[34m200918 20:28:52.329 ules/start:186 ▶ INFO 002[0m modules: started database
[31m200918 20:28:52.329 e/asm_amd6:1373 ▶ ERRO 003[0m modules: tasks should only be started when the module is online or starting
[34m200918 20:28:52.330 ules/start:186 ▶ INFO 004[0m modules: started config
[34m200918 20:28:52.332 ules/start:186 ▶ INFO 005[0m modules: started rng
[34m200918 20:28:52.332 ules/start:186 ▶ INFO 006[0m modules: started base
[34m200918 20:28:52.332 ules/start:186 ▶ INFO 007[0m modules: started subsystems
[34m200918 20:28:52.332 ules/start:098 ▶ INFO 008[0m modules: initiated subsystems manager
[34m200918 20:28:52.432 dules/mgmt:070 ▶ INFO 009[0m modules: managing changes
[34m200918 20:28:52.432 ules/start:186 ▶ INFO 010[0m modules: started netenv
[34m200918 20:28:52.432 ules/start:186 ▶ INFO 011[0m modules: started api
[34m200918 20:28:52.432 ules/start:186 ▶ INFO 012[0m modules: started notifications
[34m200918 20:28:52.432 api/router:062 ▶ INFO 013[0m api: starting to listen on 127.0.0.1:817
[34m200918 20:28:52.443 ules/start:186 ▶ INFO 014[0m modules: started updates
[34m200918 20:28:52.443 ules/start:186 ▶ INFO 015[0m modules: started geoip
[34m200918 20:28:52.443 ules/start:186 ▶ INFO 016[0m modules: started ui
[34m200918 20:28:52.444 ules/start:186 ▶ INFO 017[0m modules: started status
[33m200918 20:28:52.447 ment_linux:144 ▶ WARN 018[0m environment: could not get nameservers from dbus: No such interface “org.freedesktop.DBus.Properties” on object at path /
[34m200918 20:28:52.447 /resolvers:248 ▶ INFO 019[0m resolver: no local resolvers loaded
[34m200918 20:28:52.447 /resolvers:258 ▶ INFO 020[0m resolver: no system/network-assigned resolvers loaded
[34m200918 20:28:52.447 /resolvers:272 ▶ INFO 021[0m resolver: no scopes loaded
[34m200918 20:28:52.447 ules/start:186 ▶ INFO 022[0m modules: started resolver
[34m200918 20:28:52.462 ules/start:186 ▶ INFO 023[0m modules: started profiles
[34m200918 20:28:52.462 ules/start:186 ▶ INFO 024[0m modules: started processes
[34m200918 20:28:52.462 ules/start:186 ▶ INFO 025[0m modules: started network
[34m200918 20:28:52.507 ules/start:186 ▶ INFO 026[0m modules: started filterlists
[34m200918 20:28:52.507 ules/start:186 ▶ INFO 027[0m modules: started intel
[34m200918 20:28:52.535 ules/start:186 ▶ INFO 028[0m modules: started interception
[34m200918 20:28:52.535 ules/start:186 ▶ INFO 029[0m modules: started core
[34m200918 20:28:52.535 ules/start:186 ▶ INFO 030[0m modules: started nameserver
[34m200918 20:28:52.535 ules/start:186 ▶ INFO 031[0m modules: started filter
[34m200918 20:28:52.535 dules/mgmt:088 ▶ INFO 032[0m modules: finished managing
[34m200918 20:28:52.544 connection:207 ▶ INFO 033[0m filter: granting connection Unknown::-1 -> 127.0.0.1, special grant for connectivity domain during network bootstrap
[34m200918 20:28:52.545 ine-status:194 ▶ INFO 034[0m netenv: setting online status to SemiOnline (dns check query failed)
[34m200918 20:28:52.552 les/worker:100 ▶ INFO 035[0m nameserver: service-worker dns resolver requested restart: stopped conflicting name service with pid 9748 - restarting now
[34m200918 20:28:52.883 d-response:051 ▶ INFO 036[0m api request: 127.0.0.1:50860 HIJ /api/database/v1
[34m200918 20:28:52.883 i/database:084 ▶ INFO 037[0m api request: init websocket 127.0.0.1:50860 /api/database/v1
[34m200918 20:28:52.885 d-response:051 ▶ INFO 038[0m api request: 127.0.0.1:50862 HIJ /api/database/v1
[34m200918 20:28:52.885 i/database:084 ▶ INFO 039[0m api request: init websocket 127.0.0.1:50862 /api/database/v1
[34m200918 20:28:52.901 d-response:051 ▶ INFO 040[0m api request: 127.0.0.1:50866 HIJ /api/database/v1
[34m200918 20:28:52.901 d-response:051 ▶ INFO 041[0m api request: 127.0.0.1:50868 HIJ /api/database/v1
[34m200918 20:28:52.901 i/database:084 ▶ INFO 042[0m api request: init websocket 127.0.0.1:50866 /api/database/v1
[34m200918 20:28:52.901 i/database:084 ▶ INFO 043[0m api request: init websocket 127.0.0.1:50868 /api/database/v1
[34m200918 20:28:52.902 d-response:051 ▶ INFO 044[0m api request: 127.0.0.1:50864 HIJ /api/database/v1
[34m200918 20:28:52.903 i/database:084 ▶ INFO 045[0m api request: init websocket 127.0.0.1:50864 /api/database/v1
[34m200918 20:28:52.906 d-response:051 ▶ INFO 046[0m api request: 127.0.0.1:50870 HIJ /api/database/v1
[34m200918 20:28:52.906 i/database:084 ▶ INFO 047[0m api request: init websocket 127.0.0.1:50870 /api/database/v1
[33m200918 20:28:58.039 tel/entity:170 ▶ WARN 048[0m intel: failed to resolve IP 192.168.2.104: failed to resolve 104.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
[34m200918 20:28:58.039 connection:235 ▶ INFO 049[0m filter: dropping connection Unknown::-1 <- 192.168.2.104, endpoint is not allowed (incoming is always default=block)
[33m200918 20:29:01.455 tel/entity:170 ▶ WARN 050[0m intel: failed to resolve IP 192.168.2.127: failed to resolve 127.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
[34m200918 20:29:01.455 connection:235 ▶ INFO 051[0m filter: dropping connection Unknown::-1 <- 192.168.2.127, endpoint is not allowed (incoming is always default=block)
[33m200918 20:29:01.543 tel/entity:170 ▶ WARN 052[0m intel: failed to resolve IP 192.168.2.127: failed to resolve 127.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
[34m200918 20:29:01.543 connection:235 ▶ INFO 053[0m filter: dropping connection Unknown::-1 <- 192.168.2.127, endpoint is not allowed (incoming is always default=block)
[34m200918 20:29:02.470 all/master:084 ▶ INFO 054 [2x][0m filter: granting own connection root:/var/lib/portmaster/updates/linux_amd64/core/portmaster-core_v0-5-4:9804 to updates.safing.io. (<nil>)
[34m200918 20:29:02.475 all/master:084 ▶ INFO 055[0m filter: granting own connection root:/var/lib/portmaster/updates/linux_amd64/core/portmaster-core_v0-5-4:9804 to updates.safing.io. (116.203.130.137)
[34m200918 20:29:02.565 r/updating:077 ▶ INFO 056[0m updates: updated index stable.json
[34m200918 20:29:02.582 r/updating:077 ▶ INFO 057[0m updates: updated index beta.json
[34m200918 20:29:02.601 r/updating:077 ▶ INFO 058[0m updates: updated index all/intel/intel.json
[34m200918 20:29:02.601 r/updating:108 ▶ INFO 059[0m updates: everything up to date
[34m200918 20:29:02.613 s/upgrader:200 ▶ INFO 060[0m updates: upgraded /var/lib/portmaster/portmaster-start
[33m200918 20:29:04.039 tel/entity:170 ▶ WARN 061[0m intel: failed to resolve IP 192.168.2.104: failed to resolve 104.2.168.192.in-addr.arpa.PTR: query was blocked: no compliant resolvers for this query
[34m200918 20:29:04.039 connection:235 ▶ INFO 062[0m filter: dropping connection Unknown::-1 <- 192.168.2.104, endpoint is not allowed (incoming is always default=block)
[33m200918 20:29:09.447 ore/events:037 ▶ WARN 063[0m core: user requested shutdown
[33m200918 20:29:09.447 dules/stop:043 ▶ WARN 064[0m modules: starting shutdown...
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 065[0m modules: stopped filter
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 066[0m modules: stopped intel
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 067[0m modules: stopped geoip
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 068[0m modules: stopped nameserver
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 069[0m modules: stopped filterlists
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 070[0m modules: stopped core
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 071[0m modules: stopped ui
[34m200918 20:29:09.447 dules/stop:098 ▶ INFO 072[0m modules: stopped resolver
[34m200918 20:29:09.449 dules/stop:098 ▶ INFO 073[0m modules: stopped status
[34m200918 20:29:09.449 dules/stop:098 ▶ INFO 074[0m modules: stopped api
[34m200918 20:29:09.449 dules/stop:098 ▶ INFO 075[0m modules: stopped netenv
[34m200918 20:29:09.450 dules/stop:098 ▶ INFO 076[0m modules: stopped subsystems
[34m200918 20:29:09.450 dules/stop:098 ▶ INFO 077[0m modules: stopped notifications
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 078[0m modules: stopped interception
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 079[0m modules: stopped network
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 080[0m modules: stopped processes
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 081[0m modules: stopped profiles
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 082[0m modules: stopped updates
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 083[0m modules: stopped base
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 084[0m modules: stopped config
[34m200918 20:29:09.519 dules/stop:098 ▶ INFO 085[0m modules: stopped database
[34m200918 20:29:09.542 dules/stop:098 ▶ INFO 086[0m modules: stopped rng
[34m200918 20:29:09.542 dules/stop:052 ▶ INFO 087[0m modules: shutdown completed
[34m200918 20:29:09.552 ◀ EOF[0m
zenzen
June 26, 2024, 9:24am
3
No definitive answer on this as it was resolves by re-installing the OS. But it's suggested here to look into the logs to see what's going on. By admission of one of the developers, this is an issue with Portmaster itself; I would suggest to bring this up to their attention even if it's a rare occurrence.
opened 09:26AM - 01 Sep 22 UTC
closed 04:44PM - 17 Sep 22 UTC
bug
**What happened**:
In the shutting down and rebooting process, systemd will o… utput "A stop job is running for User Manager for UID 1000" and after around ~20 seconds it's going to stop it.
**What did you expect to happen?**:
For Portmaster to not slow down shudown/reboot process
**How did you reproduce it?**:
1. Shutdown/Reboot
2. Systemd outputs "A stop job is running for User Manager for UID 1000"
3. After ~20 seconds it's going to stop it
**Workaround**:
Workaround for this would be this command: 'nmcli radio wifi off && sudo systemctl stop portmaster ; systemctl reboot'
**Install Information**:
Distribution: Arch Linux
Kernel: 5.19.5-arch1-1 x86_64
Display server: Xorg
Desktop enviroment: Xfce
Display manager: none (running exec startxfce4 from .xinitrc at boot)
Using NetworkManager for managing network
Installed Portmaster from the [PKGBUILD](https://docs.safing.io/portmaster/install/linux#arch-linux)
**Debug Information**:
[Portmaster log](https://pastebin.com/EZJb5gqz)
system
Closed
September 24, 2024, 8:48pm
5
