Hi guys, please is it possible to run only zorin (not dual boot) on a MacBook pro 2018 and get all the drivers like the sound , WiFi and even the touch bar to work. Or you will have to run the dual boot to get those functionalities.if both will not help what about running it on a virtual box
Dual boot should not be necessary.
However, whether everything works - the best way to know is to test it. You can try it out on the LiveUSB Try Zorin as well.
MacBook users often do need to perform a few extra steps for getting Linux to work on the machine. This is not because of Linux... Both Mac OS and Linux OS are Unix-like operating systems and are very similar to each other. It is due to how Apple locks down their products.
