Zorin OS 16.2 Kernel 6.x problem
I'm using latest Zorin OS. If i install latest Kernel with Mainline Kernel Installer, OS won't boot and freeze at startup.
I have i5-13600K with Intel® UHD Graphics 770 iGPU and RTX 4080.
I need to Upgrade Kernel because Intel iGPU not working.
Since Zorin OS is not Ubuntu itself, it is not possible to replace only the kernel with Ubuntu's.
Please boot into a previous working kernel using Advanced Options for Zorin.
In terminal, install the TuxInvader Mainline:
sudo add-apt-repository ppa:tuxinvader/lts-mainline
sudo apt update && sudo apt install linux-generic-6.02
Reboot and test your system on the Tux Invader kernel to see if igpu (Which seems to be needing >5.19) is working. You may need the 525, not 535 Nvidia Drivers selected (Software & Updates > Additional Drivers Tab).
If it is not working, we could try the Liqourix kernel...
