Hello, good morning, sorry for the inconvenience, but today it happened to me that I wanted to start a session on my PC, as always, and then I turned it off, I came back in a few hours, and I found that my PC does not load.
I also tried using the ALT+F2 command to try to open the terminal, but I only got a text asking for login, but then the text disappeared, and I couldn't type anything.
Are you dual booting with Windows - Is Secure Boot enabled or Disabled in BIOS EFI settings?
What Graphics card(s) are you using?
If you tap esc or tab at the Motherboard splash screen, are you able to access the Grub menu?
From the Grub Menu, you can access Advanced Options for Zorin and try an earlier kernel.
Or you can select Zorin (recovery) and run the FSCK (File System Check) option from the recovery menu.
SGX (Intel Software Guard Extensions) is enabled or disabled within the BIOS settings. I am not sure where given that it can depend on the Manufacturer - you may need to look that up by your specific make and model. It is not inhibiting Boot and not important to deal with this right away.
Secure Boot would be in the Security Tab of the BIOS settings.
I can only suggest trying again - try different timing... If those are not working, you may be using MBR (Legacy) boot - in which case instead, hold down the left shift key
Also, I've been checking, also, I've been getting that error before, but it said that it no longer had storage space on the disk, and it doesn't matter what it will delete, it kept saying that it was busy on 100%
I bet TimeShift backups are what have filled your drive to the brim. You can access the Settings in Timeshift to have it remove old backups as new ones are saved. I highly recommend doing this.
In the meantime, if you need to clear out TimeShift backups, you may need to use the recovery menu > drop to prompt,
then list out the folder contents:
ls ~/timeshift
Then use the rm command to remove the old entries, leaving only the latest backup in case you need it.
I already deleted some folders, it no longer shows that 100% of the partition is used.
but the problem still persists, and when I hit "fsck" I get this:
Although something very strange happened, when I pressed ctrl + F2, a text appeared asking for a password, when I put a password I logged in and I'm already using Zorin OS, but I don't understand what happened
If you are logged in to the desktop, please launch the Disk Analyzer app from the app menu and note what is taking up so much space. We can then see if that can be reduced.
Once that is done, we may need to check the integrity of all programs with
