Zorin OS 16 question
https://zoom.us/client/latest/zoom_amd64.deb
I can remove 3 Gb off my Drive now
Ow no I realised I need to use Telegram
http://ftp.br.debian.org/debian/pool/main/t/telegram-desktop/telegram-desktop_1.5.11-1_amd64.deb
Bruh, I don't need snaps and flatpak anymore
It's a snap to send flatpak packin'
and tell Snap to pack it up
You got your system back to black
'cuz Aravisian got your back
Bruh...
...my sides hurt...
I have a problem, the deb files end up with errors. Is it a dependency problem?
Telegram
 kedric@kp-laptop:~$ sudo dpkg -i '/home/kedric/Downloads/telegram-desktop_1.5.11-1_amd64.deb'
 Selecting previously unselected package telegram-desktop.
 (Reading database ... 304428 files and directories currently installed.)
 Preparing to unpack .../telegram-desktop_1.5.11-1_amd64.deb ...
 Unpacking telegram-desktop (1.5.11-1) ...
 dpkg: dependency problems prevent configuration of telegram-desktop:
  telegram-desktop depends on qt5-image-formats-plugins (>= 5.5); however:
   Package qt5-image-formats-plugins is not installed.
  telegram-desktop depends on libminizip1 (>= 1.1); however:
   Package libminizip1 is not installed.
  telegram-desktop depends on libxxhash0 (>= 0.6.5); however:
   Package libxxhash0 is not installed.
  telegram-desktop depends on qtbase-abi-5-11-3; however:
   Package qtbase-abi-5-11-3 is not installed.
 dpkg: error processing package telegram-desktop (--install):
 Processing triggers for desktop-file-utils (0.24-1ubuntu3) ...
 Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
 Processing triggers for mime-support (3.64ubuntu1) ...
 Processing triggers for hicolor-icon-theme (0.17-2) ...
 Processing triggers for man-db (2.9.1-1) ...
  telegram-desktop
Zoom
kedric@kp-laptop:~$ sudo dpkg -i '/home/kedric/Downloads/zoom_amd64.deb'
Selecting previously unselected package zoom.
Preparing to unpack .../Downloads/zoom_amd64.deb ...
Unpacking zoom (5.7.31792.0820) ...
dpkg: dependency problems prevent configuration of zoom:
 zoom depends on libegl1-mesa; however:
  Package libegl1-mesa is not installed.
 zoom depends on libxcb-xtest0; however:
  Package libxcb-xtest0 is not installed.
dpkg: error processing package zoom (--install):
Processing triggers for shared-mime-info (1.15-1) ...
 zoom
I am not sure if any of those are going to throw additional errors- but let's try installing them to find out:
sudo apt install qt5-image-formats-plugins libminizip1 libxxhash0 qtbase-abi-5-11-3 libegl1-mesa libxcb-xtest0
Your solution gave me just gave me bunch of errors, after me trying I was quite annoyed if I do say so myself but then the terminal told me to run sudo apt --fix-broken install and it fixed everything. I now learned another thing in Linux.
My installation got broke as well, had to reinstall the zorin os as well. Not sure if it had to do with the steps i followed or with the ppa i used to install nvidia drivers.
This topic was automatically closed after 2 days. New replies are no longer allowed.
