Yes, I did.
Then the only thing I can think of is a difference between our hardware.
Mine is original Apple Magic Trackpad.
Where can I see which devices I have?
Is it a separate trackpad like mine?
Or is it a part of your system (i.e., laptop).
It's built into my laptop.
Issue this command then
lspci
and give me the output.
I have the "SynPS/2 Synaptics TouchPad".
I found out in the terminal. I found out how to find it on the internet.
Since I do not have this particular hardware, I am afraid you have to wait for other volunteers to pitch in to help you.
Okay. Still thank you for your help!
I think you can get out the info by the model: hp EliteBook 8470w.
I also have HP EliteBook 8470p (not my main).
But I've never tried multi gesture on this one.
Trackpad is too small for may taste.
[edit]
I installed Touche to this HP just to test it out for you.
You are right.
The multitouch is not working on this built in trackpad.
Some more research:
Ubuntu 18.4 comes with libinput touchpad driver by default and the OS is missing Synaptics touchpad driver.
At least this explains why this trackpad in Elitebook does not work OOB with Touche.
So there is a problem with the synaptics driver on my device? Or isn't it installed or is my device not compatible?
Touche requires libinput.
You have Synaptic. so it is incompatible.
But if you follow the above linked tutorial, it seems limited gestures could be implemented.
What do you see with the command below?
xinput list
For now I can't check that. I will do this tomorrow.
This is a line of the output. (nealry): "SynPS/2 Synaptics TouchPad".
Is the touchpad itself incompatible or could I use libinput drivers? I think it's because of the trackpad itself.
I need to see the entire output.
Can you copy and paste it here?
| ⎡ Virtual core pointer | id=2 | [master pointer (3)] |
| ⎜ ↳ Virtual core XTEST pointer | id=4 | [slave pointer (2)] |
| ⎜ ↳ Logitech Wireless Keyboard PID:4023 | id=14 | [slave pointer (2)] |
| ⎜ ↳ Compx 2.4G Wireless Receiver Consumer Control | id=12 | [slave pointer (2)] |
| ⎜ ↳ HanWang Tablet Mouse | id=9 | [slave pointer (2)] |
| ⎜ ↳ PS/2 Generic Mouse | id=18 | [slave pointer (2)] |
| ⎜ ↳ SynPS/2 Synaptics TouchPad | id=19 | [slave pointer (2)] |
| ⎜ ↳ Compx 2.4G Wireless Receiver | id=10 | [slave pointer (2)] |
| ⎜ ↳ Logitech Wireless Mouse | id=15 | [slave pointer (2)] |
| ⎣ Virtual core keyboard | id=3 | [master keyboard (2)] |
| ↳ Virtual core XTEST keyboard | id=5 | [slave keyboard (3)] |
| ↳ Video Bus | id=7 | [slave keyboard (3)] |
| ↳ Compx 2.4G Wireless Receiver System Control | id=13 | [slave keyboard (3)] |
| ↳ HP WMI hotkeys | id=21 | [slave keyboard (3)] |
| ↳ Logitech Wireless Keyboard PID:4023 | id=23 | [slave keyboard (3)] |
| ↳ Compx 2.4G Wireless Receiver Consumer Control | id=22 | [slave keyboard (3)] |
| ↳ Compx 2.4G Wireless Receiver Keyboard | id=11 | [slave keyboard (3)] |
| ↳ HP HD Webcam [Fixed]: HP HD Web | id=16 | [slave keyboard (3)] |
| ↳ HP Wireless hotkeys | id=20 | [slave keyboard (3)] |
| ↳ AT Translated Set 2 keyboard | id=17 | [slave keyboard (3)] |
| ↳ Sleep Button | id=8 | [slave keyboard (3)] |
| ↳ Power Button | id=6 | [slave keyboard (3)] |
Can you issue this command in terminal?
sudo apt install xserver-xorg-input-synaptics
and paste output here.
It was installed. What now?
