Hello folks,
newbie here.
After installing OS17 Core my network card is connected by LAN cable its detected, but no internet.
Any hints what might be a wrong here, why its not pulling over internet?
Thanks
Hello folks,
newbie here.
Thanks
Can you please post the terminal output for
sudo lshw -C network
Did You tried simply to restart Your Router? And did You control that the Cable sits like it should? I know this sounds maybe a little bit stupid but sometimes the easiest Things are the Solution.
