Zorin Os Busy Box Problem
busy box error fsck not working anyone can help me🙄
I hoped the fix was explained there :point_down::disappointed:, it's the same identical issue.
But you can see if disabling the touchpad on BIOS allows the system to be initialized anyway until you find a way to fix the issue.
I am trying to install zorin & this happened now my laptop doesn't have any os waiting for solution​:slightly_smiling_face::+1:
Have you followed the steps:
https://medium.datadriveninvestor.com/how-to-fix-busybox-initramfs-error-on-ubuntu-20-1-71ee71dc4060
Did you get a reportable error to fsck?
Did you change BIOS back to boot from hard drive?
If yes,
Try this :
(initramfs) fsck /dev/sda? -y
( replace '?' with your 'partition ID' )
lsblk ,
(to find partition ID)
then
exit.
Hope this helps
It says fsck not found
