Hi There,
after following the guide on Set Up Microsoft Surface Device - Zorin Help I managed to use zorin on the surface 8 pro. During installation i decided to encrypt the disk and do create a lvm (using the wizard).
Following the above guide i encounter an error on step
4: ```
sudo systemctl enable iptsd
stating
Failed to enable unit: Unit file iptsd.service does not exist.
Nevertheless, I can use both touchscreen an attached keyboard (including touchpad plus pen). uname -a tells me that the surface kernel is installed:
Linux sofia-Surface-Pro-8 6.9.3-surface-2 #2 SMP PREEMPT_DYNAMIC Mon Jun 10 23:37:21 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
BUT if i restart the surface i cannot enter the decryption key without using an external keybaord connected over USB. While starting the keyboard icon appears in the lower right corner, touching it activates the on-screen-keys, but they disappear, when the decryption key is to be entered.
During startup there is a message stating that "Volume group `vgzorin` not found" followed by "Cannot process volume group vgzorin". Looking at the drives, the only encrypted drive is partition 3 containing root system. EFi/boot and swap are not encrypted, as far as i understand.
I tried to reinstall iptsd, it works with no errors, but still is an unknown service when i try to enable it.
Could you please give me a hint how to proceed? ANy help is much appreciated.
Thanks in advance,
limr
