Specifications of my laptop.
Model: HP Pavilion 14-b117es
CPU: 1,8 GHz Intel Core i5-3337U
RAM: DDR3 6GB
HDD: SATA 750 GB 5400 rpm
GPU: Intel HD 4000 (1,65 GB)
I want to completely remove Windows from my computer, as it is a few years old, it is not compatible with Windows 11 and Windows 10 works very badly. So I want to have on my computer only Zorin OS.
In the Zorin OS installer does not detect my hard drive, nor does it detect Windows 10. When I go to the disk partitions nothing appears, only the USB.
I don't know if it is because of some BIOS configuration. I have been looking and for example the hard disk is split in two, and in RAID0 (I do not know the reason because the PC has only one hard disk), I do not see any option to put it in AHCI, although I do not know if the reason for not appearing is the RAID0. I do not know if it is because the hard disk is in NTFS and for that reason it does not appear? The truth is that I am very lost, it is the first time I install Linux on a computer and not in a virtual machine.
Thanks in advance to all.
