I recently installed Zorin OS on my PC as an alternative to Windows, I had a small problem with frequent freezes which were only solved by turning off the pc forcefully, but after installing the drivers the frequency decreased considerably, but still on some rare occasions certain crashes and freezes occur, I'm new to Linux, I've used Windows for more than 10 years in my life, so I'm really lost
I'm back with updates, the freezes would drop dramatically, I just had one while I was playing
I noticed that the freeze is system-wide, I say that because when I tried to turn off and on the num lock, which normally signals with a led on or off, there was no response
and after a while, it seems that the system is responding again but I had to restart anyway to fix it
I believe I've found the cause of the problem, I've noticed that the crash always starts when the RAM is being completely used up
I don't have any swap configured to reserve memory for the system, so I believe that the applications are consuming all the memory and the system is running out, I have decreased the frequency of simultaneous apps consequently resulting in less RAM being consumed and no more freezes have occurred
Thank you very much to those who paid attention to this post, I'm going to buy a new RAM comb and set up the Swap
