Zorin OS Portable Installation - recommended?
Hello,
I am planning to install (yet another) copy of Zorin OS on my new PC. This time, I want to install it on an USB Stick, to be able to boot from Windows to Zorin from different drives. Is it recommended to do that? My PC model is a MS Surface Laptop Go 3 and my Drive a SanDisk with 128 GB of Storage. I have already made it bootable with the Zorin ISO Files. Thank you.
I know people do this, and it is an option to do, but I personally wouldn't recommend it. USB Drives are prone to errors at the best of times, and if one day all of a sudden the drive decides to give up, you've lost your OS and everything related to it on the drive.
I would rather attempt a second drive in the PC before doing that, or even an external SSD / HDD (Ideally SSD) as they at least are not nearly as prone to sudden onset failure. Personally I used to just Dual Boot on a single drive with multiple partitions, but I know a lot of people would rather just have a single drive for each OS.
But why? I can't install a second drive and the external SSD cost way to much.
If you are talking about using a USB with Persistence then it would be better to have your /home folder on another USB. USB sticks are a micro version of SSD's and continuous rewrites will shorten the life of the USB. Even a small USB HDD would be better than a USB stick.
If usb C required:
https://www.amazon.co.uk/dp/B0DRSQ7MPY?_encoding=UTF8&tag=sm20-21&linkCode=ur2&linkId=63c11016db7bd19cd7d42bd13be959d9&camp=1634&creative=6738
I already have one.
I mean having Zorin installed on a Stick.
The issue with installing any OS to USB drive is that it will have a relatively short shelf life due to numerous rewrites, especially as Ext4 is a journaling system. That is why I suggested having Zorin OS installed on one USB and have your data kept on another.
But my PC only has 1 USBC port and 1 USB port, which are so close together, I can only have 1 plugged in at a time. And my budget is limited, I don't think I can buy a USB hub.
