Good day Devs ,Like a lot of people MS has died for me. Working with Zorin what a pleasure , I there any plans to add a reset feature , I'm testing all Zorin versions and running them in Proxmox and and but a simple reset will go along way , make the backup the users problem just a reset function will be so welcomed. Thank you Zorin and team and devs , Pro is such a good idea happy to pay for a well polished and well developed software. Thanks Hano
It has often been suggested that such a feature be added to Zorin, but unfortunately it does not exist yet. I really miss it, too.
You can, for example, install timeshift to back up your system (by default /home directory is excluded there from backup) and use deja dup to back up your /home directory.
You can also use rescuezilla to make a complete backup of your system once you have installed all the apps you need. I've always backed up /home (including hidden files) manually to external drive.
