it worked and it is now disabled, but there is still an error in boot repair. about NVram being locked (Zorin not found in efibootmgr). and the gnu brub menu is still here repeating the same thing hahaha
Did you perform all of the above?
yes i did.
If possible, I would remove the CMOS Battery. If you cannot remove the CMOS Battery, proceed with the below anyway.
After removing CMOS battery, hold the power button down and keep holding it down for thirty seconds to allow all capacitors to drain.
Boot into Zorin and run the two commands above for sudo grub-install and to update-grub
