Zorin OS Theme Issues on Arch Linux
Hi!I have issues with Top Bar (on Activities icon) and on Quick Settings which goes wrong!
Has anyone an idea?
Screenshot 2024-02-17 234758
Well Zorin OS layouts were built for Zorin, not Arch which hardly comes with anything.
You have to check the extension settings with an extension manager. Zorin has a lot of extensions added to make it look custom.
Arch is most likely using a newer version of gnome and this could be a source for the problem. The Arch repository typically hosts the newest cutting edge packages versions.
