Zorin OS Wayland: How to fix legacy blue title bars on Spotify and Chrome?
Hello everyone,
I'm using Zorin OS with a Wayland session and I'm facing an annoying visual issue with some applications. Apps like Spotify (both Flatpak and .deb) and the Google Chrome profile picker window are showing a blue, legacy-style title bar (it looks like Windows 95/classic theme) instead of the native window decorations.
On Xorg (X11), the windows look perfectly fine.
spotify wayland
What I've verified so far:
  • I checked GNOME's Looking Glass (lg), and the windows are indeed running as native Wayland surfaces (metaSurfaceActorWayland), not XWayland.
  • In Chrome, Preferred Ozone platform is set to Wayland. The main browser window is fine, but the "Who's using Chrome?" startup window always shows the blue bar.
  • For Spotify, I tried launching with: --enable-features=UseOzonePlatform --ozone-platform=wayland and even --enable-features=WaylandWindowDecorations. The app runs in Wayland, but the blue border persists.
It seems like Mutter is forcing a Server-Side Decoration (SSD) fallback because these apps aren't communicating their CSD (Client-Side Decorations) correctly to the Zorin environment.
System Info:
  • OS: Zorin OS 18
  • Session: Wayland
  • Apps affected: Spotify, Chrome (Profile Picker), and some other apps.
  • VGA: 9070XT With MESA 25.3
Has anyone found a way to force these apps to use the system theme or at least hide this blue fallback bar?
Thanks in advance!
Did You have added any Third-Party Themes? Even when they are no longer used.
It's a cross all distro its affected. Tested on elementary OS and Solus OS. So it's not specific to Zorin. My guess is that Spotify is packed wrongly from host.
No, it's a default installation of ZorinOS 18 Pro. I only selected the Windows 10-like theme in Zorin Appearance. However, the issue persists even if I select any other theme within Zorin Appearance. The problem only disappears if I log in using XORG (X11) instead of Wayland. But I want to use Wayland because of my 165Hz and 144Hz monitors; on XORG, the refresh rate feels off/jittery.
So, do I have to wait for a fix from the app developers?
I actually meant Themes. For making a different Look for Your System. Not Layouts.
It's been the same for me since the update. I have Zorin OS 18 Standard Theme. I think we'll have to wait for a fix from the app developers.
More Infos https://www.reddit.com/r/Ubuntu/comments/1rdrss5/how_to_remove_ugly_blue_bar_on_top/?tl=de
Alright, in that case, let's just wait for a fix from the developers.
The solution is actually simple, you just need to force spotify to use X11 support instead of buggy and ugly wayland. Since spotify is an electron app, wayland support is really problematic like always.
If you want to stay in wayland and still want an easy solution (tested for official snap package, since the top result on software store is flatpak and it's not the official one):
Run this on the terminal:
spotify --by-sglbl --ozone-platform=x11
If you want to make this default, from menu open "Main Menu" (or on a theme with top-panel, right click and select "Edit Menu" and follow the steps:
