Hi,
I have an old Macbook Pro 2009(system requirement all met) and would like to switch to Zorin Pro 16 for the first time. I follow the entire installation procedure post on the website(I chose the erase everything option since i can't upload the new IOS anymore). No problem running through the USB flash, checking process and installation. After the installation is completed, it restarts and request to remove the USB that was plugged in. Then i remove and press enter and the computer restarts. It starts with the Zorin logo and the Letter Zorin after. Then it stucks in a blue screen and won't move on to the log in screen. I tried reinstall twice the system and still the same result. What should I do now? Did I miss any hidden steps or I need to change some setting in bios or elsewhere in the computer? Please advise. Thanks a lot.
