hi
there is a problem with my lock screen after installing zorin os 17 pro
when I lock my screen after a while after entering my password picture going dark and then lock screen show up
after I re-enter my password everything get reset and all my opened apps get close
Please help me about this problem thanks.
Zorin OS 17 defaults to Wayland.
Can you test logging on on Zorin on X desktop
, open some things as if you are working on them, then locking the screen and see if you have the same behavior?
