It has an icon that says “a problem occurred while checking for updates”. Then I click on “Show Updates”. However, when viewing in task manager the script does not load.
May 23 08:36:09 jeiel-To-be-filled-by-O-E-M kernel: [ 1847.694231] audit: type=1400 audit(1684841769.647:1875): apparmor="DENIED" operation="create" info="failed type and protocol match" error=-13 profile="/usr/sbin/cups-browsed" pid=847 comm="cups-browsed" family="unix" sock_type="stream" protocol=0 requested_mask="create" denied_mask= "create" addr=none
Anyway… I don't know the problem on my Zorin OS (Lite). I hope your help to solve this case.
I already ran the commands "update" and "upgrade". I also restarted the PC.
There may be an issue with the Regional to Main servers.
In Software & Updates on the first tab, switch "Download from" to "Main server" from the dropdown menu.
In terminal, run:
jetrom, I am not sure why you are showing the Processes of CPU usage... Am I misunderstanding the problem?
As I understood it, the issue is that the updater reported that it failed to update, yet the terminal says all packages are up to date.
Is there a different issue such as that a process like the .py script is running in the background and you do not want it to?
Let's not focus on that. It is misleading.
The software-properties-gtk app is the Software & Updates app.
The Update-manager is processed through the .py script. These are necessarily going to run, so observing that they run is not indicative of anything other than that they run.
The .py script itself does not contain the error because if it did; then that error would show on all systems running it.
The error is far more likely to occur due to a difference between the logged updates and the communicated updates via the server.
