Zorin stuck at grub> at startup in dual boot system
I have an older Windows computer that has one drive with Windows 7, one drive with Windows 10 and a third SSD with Zorin 18 Pro. Bios is not set to UFI mode. I used EasyBCD to set up a triple boot configuration, which has the bootloader pat set to \NST\AutoNeoGrub0.mbr
When I start the computer with the \NST\AutoNeoGrub0.mbr bootloader, the computer winds up with grub> I do not know how to proceed.
I'm sort of in the blind because I do not know how to see the Zorin files with Windows.
I ran a Linix boot repair disc and it generated the following report:
boot-repair-4ppa2081                                              [20251105_0002]
============================= Boot Repair Summary
Recommended repair: ____________________________________________________________
The default repair of the Boot-Repair utility will reinstall the grub2 of
sdc5 into the MBR of sdc.
Grub-efi will not be selected by default because legacy Windows detected.
Additional repair will be performed: unhide-bootmenu-10s
/boot/efi removed in sdc5/fstab
Unhide GRUB boot menu in sdc5/etc/default/grub
======================= Reinstall the grub2 of /dev/sdc5 =======================
chroot /mnt/boot-sav/sdc5 grub-install --version
grub-install (GRUB) 2.12-1ubuntu7.3+zorin2
==> Reinstall the GRUB of /dev/sdc5 into the MBR of /dev/sdc
chroot /mnt/boot-sav/sdc5 grub-install /dev/sdc
Installing for i386-pc platform.
Installation finished. No error reported.
chroot /mnt/boot-sav/sdc5 update-grub
Sourcing file `/etc/default/grub'
Found theme: /usr/share/grub/themes/zorin/theme.txt
Found linux image: /boot/vmlinuz-6.14.0-33-generic
Found initrd image: /boot/initrd.img-6.14.0-33-generic
Found Windows 10 on /dev/sda2
Found Windows 7 on /dev/sda3
Found Windows 10 on /dev/sdb1
Adding boot menu entry for UEFI Firmware Settings ...
Unhide GRUB boot menu in sdc5/boot/grub/grub.cfg
Boot successfully repaired.
You can now reboot your computer.
Please do not forget to make your BIOS boot on sdc (ATA CT1000BX500SSD1) disk!
The boot files of [sdc5 (end>100GB)] are far from the start of the disk. Your BIOS may not detect them.
You may want to retry after creating a /boot partition (EXT4, >200MB, start of the disk). This can be
performed via tools such as gParted. Then select this partition via the [Separate /boot partition:] option of
[Boot Repair]. (https://help.ubuntu.com/community/BootPartition)
============================ Boot Info After Repair ============================
 => Windows is installed in the MBR of /dev/sda.
 => Windows is installed in the MBR of /dev/sdb.
 => Grub2 (v2.00) is installed in the MBR of /dev/sdc and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos5)/boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk
sda1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  Windows XP: FAT32
    Boot sector info:  No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:
sda2: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  NTFS
    Operating System:  Windows 7
    Boot files:        /bootmgr /Boot/BCD /Windows/System32/winload.exe
sda3: __________________________________________________________________________
    File system:       ntfs
sda4: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  Unknown
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 2000/XP: NTFS
    Boot sector info:  According to the info in the boot sector, sda5 starts
                       at sector 63.
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sda6 starts
                       at sector 63.
    Operating System:
    Boot files:
sdb1: __________________________________________________________________________
    File system:       ntfs
    Boot sector type:  Windows 7/2008: NTFS
    Operating System:  Windows 8 or 10
sdb2: __________________________________________________________________________
    Boot sector type:  -
    Boot sector info:
sdb5: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sdb5 starts
                       at sector 63.
    Operating System:
    Boot files:
sdb6: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sdb6 starts
                       at sector 63.
    Operating System:
    Boot files:
sdb7: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sdb7 starts
                       at sector 63.
    Operating System:
    Boot files:
sdb8: __________________________________________________________________________
    File system:       ntfs
    Boot sector info:  According to the info in the boot sector, sdb8 starts
                       at sector 63.
    Operating System:
    Boot files:
sdc1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  FAT32
    Operating System:
    Boot files:
sdc2: __________________________________________________________________________
    Boot sector type:  -
    Boot sector info:
sdc5: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:  Zorin OS 18
    Boot files:        /boot/grub/grub.cfg /etc/fstab /etc/default/grub
                       /boot/grub/i386-pc/core.img
================================ 4 OS detected
OS#1 (windows):   Windows 10 on sda2
OS#2 (windows):   Windows 7 on sda3
OS#3 (windows):   Windows 10 on sdb1
OS#4 (linux):   Zorin OS 18 (18) on sdc5
================================ Host/Hardware
CPU architecture: 64-bit
Video: GK106 [GeForce GTX 650 Ti Boost] from NVIDIA Corporation
Live-session OS is Linuxmint 64-bit (Linux Mint 21.2, victoria, x86_64)
===================================== UEFI
BIOS/UEFI firmware: 2103(4.6) from American Megatrends Inc.
The firmware is EFI-compatible, but this live-session is in Legacy/BIOS/CSM mode (not in EFI mode).
b4041c77d7f10c36861203da493662ef   sda3/Boot/bootx64.efi
b4041c77d7f10c36861203da493662ef   sda3/Microsoft/Boot/bootmgfw.efi
76c1ab75037265cbe84a872c44ddcec2   sda3/Microsoft/Boot/bootmgr.efi
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
sda	: notGPT,	no-BIOSboot,	has-noESP, 	not-usb,	not-mmc, has-os,	has-win,
	63 sectors * 512 bytes
sdb	: notGPT,	no-BIOSboot,	has-noESP, 	not-usb,	not-mmc, has-os,	has-win,
sdc	: notGPT,	no-BIOSboot,	has---ESP, 	not-usb,	not-mmc, has-os,	no-wind,
	2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
sda1	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	not-far
sda2	: is-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sda3	: is-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sda5	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sda6	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdb1	: is-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdb5	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdb6	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdb7	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdb8	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	end-after-100GB
sdc1	: no-os,	64, nopakmgr,	no-docgrub,	nogrub,	nogrubinstall,	no-grubenv,	noupdategrub,
	not-far
sdc5	: is-os,	64, apt-get,	signed grub-pc grub-efi ,	grub2,	grub-install,	no-grubenv,
	update-grub,	end-after-100GB
Partitions info (2/3): _________________________________________________________
sda1	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
bmgr,	notwinboot, vfat
sda2	: isnotESP,	part-has-no-fstab,	no-nt,	haswinload,	no-recov-nor-hid,
	bootmgr,	is-winboot, ntfs
sda3	: isnotESP,	part-has-no-fstab,	no-nt,	haswinload,	no-recov-nor-hid,
sda5	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
bmgr,	notwinboot, ntfs
sda6	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdb1	: isnotESP,	part-has-no-fstab,	no-nt,	haswinload,	no-recov-nor-hid,
sdb5	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdb6	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdb7	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdb8	: isnotESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdc1	: is---ESP,	part-has-no-fstab,	no-nt,	no-winload,	no-recov-nor-hid,	no-
sdc5	: isnotESP,	fstab-has-goodEFI,	no-nt,	no-winload,	no-recov-nor-hid,	no-
bmgr,	notwinboot, ext4
Partitions info (3/3): _________________________________________________________
sda1	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
has-no-fstab,	no--grub.d,	sda
sda2	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sda3	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sda5	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sda6	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sdb1	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
has-no-fstab,	no--grub.d,	sdb
sdb5	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sdb6	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sdb7	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sdb8	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
sdc1	: not--sepboot,	no---boot,	part-has-no-fstab,	not-sep-usr,	no---usr,	part-
has-no-fstab,	no--grub.d,	sdc
sdc5	: not--sepboot,	with-boot,	fstab-without-boot,	not-sep-usr,	with--usr,	fstab-
without-usr,	std-grub.d,	sdc
fdisk -l (filtered): ___________________________________________________________
Disk sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk identifier: 0x93c973c1
     Boot      Start        End    Sectors   Size Id Type
sda1               63    5397839    5397777   2.6G  b W95 FAT32
sda2  *       5413900  564138539  558724640 266.4G  7 HPFS/NTFS/exFAT
sda3        564154598  923432264  359277667 171.3G  7 HPFS/NTFS/exFAT
sda4        923448318 1953520064 1030071747 491.2G  f W95 Ext'd (LBA)
sda5        923448381 1439697104  516248724 246.2G  7 HPFS/NTFS/exFAT
sda6       1439713221 1953520064  513806844   245G  7 HPFS/NTFS/exFAT
Disk sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk identifier: 0x830450a5
sdb1  *            63  419441084  419441022   200G  7 HPFS/NTFS/exFAT
sdb2        419441085 1953520064 1534078980 731.5G  5 Extended
sdb5        419441148  726636014  307194867 146.5G  7 HPFS/NTFS/exFAT
sdb6        726636078  931448699  204812622  97.7G  7 HPFS/NTFS/exFAT
sdb7        931448763 1443440249  511991487 244.1G  7 HPFS/NTFS/exFAT
sdb8       1443440313 1953520064  510079752 243.2G  7 HPFS/NTFS/exFAT
Disk sdc: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk identifier: 0xf11a3919
sdc1  *       2048    1050623    1048576  512M ef EFI (FAT-12/16/32)
sdc2       1052670 1953523711 1952471042  931G  f W95 Ext'd (LBA)
sdc5       1052672 1953523711 1952471040  931G 83 Linux
parted -lm (filtered): _________________________________________________________
sda:1000GB:scsi:512:512:msdos:ATA WDC WD1002FAEX-0:;
1:32.3kB:2764MB:2764MB:fat32::;
2:2772MB:289GB:286GB:ntfs::boot;
3:289GB:473GB:184GB:ntfs::;
4:473GB:1000GB:527GB:::lba;
5:473GB:737GB:264GB:ntfs::;
6:737GB:1000GB:263GB:ntfs::;
sdb:1000GB:scsi:512:512:msdos:ATA WDC WD1002FAEX-0:;
1:32.3kB:215GB:215GB:ntfs::boot;
2:215GB:1000GB:785GB:::;
5:215GB:372GB:157GB:ntfs::;
6:372GB:477GB:105GB:ntfs::;
7:477GB:739GB:262GB:ntfs::;
8:739GB:1000GB:261GB:ntfs::;
sdc:1000GB:scsi:512:512:msdos:ATA CT1000BX500SSD1:;
1:1049kB:538MB:537MB:fat32::boot, esp;
2:539MB:1000GB:1000GB:::lba;
5:539MB:1000GB:1000GB:ext4::;
blkid (filtered): ______________________________________________________________
NAME   FSTYPE   UUID                                 PARTUUID                             LABEL
PARTLABEL
sda
+-sda1 vfat     1F18-422D                            93c973c1-01                          BOOT
+-sda2 ntfs     6EEA8304EA82C7B3                     93c973c1-02                          Windows7
+-sda3 ntfs     01D1CA97C5905CE0                     93c973c1-03                          Windows7_New
+-sda4                                               93c973c1-04
+-sda5 ntfs     01CEBA331435ED60                     93c973c1-05                          CD_Files
+-sda6 ntfs     01CEBA3315560360                     93c973c1-06                          DVD_Files
sdb
+-sdb1 ntfs     6EEA8304EA82C7B3                     830450a5-01                          Windows10
+-sdb2                                               830450a5-02
+-sdb5 ntfs     01CEBA306A640760                     830450a5-05                          Files
+-sdb6 ntfs     01CEBA306CD618D0                     830450a5-06                          Internet
+-sdb7 ntfs     01CEBA3211670B60                     830450a5-07                          Photos
+-sdb8 ntfs     01CEBA3213BC9420                     830450a5-08                          Storage
sdc
+-sdc1 vfat     EB03-3CEA                            f11a3919-01
+-sdc2                                               f11a3919-02
+-sdc5 ext4     9b141543-1eda-408b-a1ff-c57d9150c0de f11a3919-05
sdd
sde
sdf
sdg
sdh
sdi
sdj
Mount points (filtered): _______________________________________________________
            Avail Use% Mounted on
/dev/sda1     2.6G   0% /mnt/boot-sav/sda1
/dev/sda2   163.3G  39% /mnt/boot-sav/sda2
/dev/sda3    97.3G  43% /mnt/boot-sav/sda3
/dev/sda5    98.1G  60% /mnt/boot-sav/sda5
/dev/sda6   215.1G  12% /mnt/boot-sav/sda6
/dev/sdb1   123.8G  38% /mnt/boot-sav/sdb1
/dev/sdb5    48.7G  67% /mnt/boot-sav/sdb5
/dev/sdb6    60.3G  38% /mnt/boot-sav/sdb6
/dev/sdb7   226.2G   7% /mnt/boot-sav/sdb7
/dev/sdb8    63.3G  74% /mnt/boot-sav/sdb8
/dev/sdc1     511M   0% /mnt/boot-sav/sdc1
/dev/sdc5   848.8G   2% /mnt/boot-sav/sdc5
Mount options (filtered): ______________________________________________________
/dev/sda1   vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-
1,shortname=mixed,errors=remount-ro
/dev/sda2   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sda3   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sda5   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sda6   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdb1   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdb5   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdb6   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdb7   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdb8   fuseblk         rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
/dev/sdc1   vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-
/dev/sdc5   ext4            rw,relatime
====================== sdc5/boot/grub/grub.cfg (filtered) ======================
Zorin OS   9b141543-1eda-408b-a1ff-c57d9150c0de
Windows 10 (on sda2)   6EEA8304EA82C7B3
Windows 7 (on sda3)   01D1CA97C5905CE0
Windows 10 (on sdb1)   6EEA8304EA82C7B3
### END /etc/grub.d/30_os-prober ###
UEFI Firmware Settings   uefi-firmware
### END /etc/grub.d/30_uefi-firmware ###
========================== sdc5/etc/fstab (filtered) ===========================
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdc5 during installation
UUID=9b141543-1eda-408b-a1ff-c57d9150c0de /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sdc1 during installation
/swapfile                                 none            swap    sw              0       0
======================= sdc5/etc/default/grub (filtered) =======================
GRUB_DEFAULT=0
GRUB_TIMEOUT_STYLE=menu
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`( . /etc/os-release; echo ${NAME:-Ubuntu} ) 2>/dev/null || echo Ubuntu`
GRUB_CMDLINE_LINUX=""
GRUB_DISABLE_OS_PROBER=false
GRUB_THEME=/usr/share/grub/themes/zorin/theme.txt
GRUB_DISABLE_MEMTEST=true
==================== sdc5: Location of files loaded by Grub ====================
           GiB - GB             File                                 Fragment(s)
            ?? = ??             boot/grub/grub.cfg                             1
  31.914302826 = 34.267721728   boot/grub/i386-pc/core.img                     1
   2.336746216 = 2.509062144    boot/vmlinuz                                   1
   2.336746216 = 2.509062144    boot/vmlinuz-6.14.0-33-generic                 1
   2.336746216 = 2.509062144    boot/vmlinuz.old                               1
   2.322261810 = 2.493509632    boot/initrd.img                                2
   2.322261810 = 2.493509632    boot/initrd.img-6.14.0-33-generic              2
   2.322261810 = 2.493509632    boot/initrd.img.old                            2
===================== sdc5: ls -l /etc/grub.d/ (filtered) ======================
-rwxr-xr-x 1 root root 18123 May 17 13:12 10_linux
-rwxr-xr-x 1 root root 43192 May 17 13:12 10_linux_zfs
-rwxr-xr-x 1 root root 14513 May 17 13:12 20_linux_xen
-rwxr-xr-x 1 root root   786 May 17 13:12 25_bli
-rwxr-xr-x 1 root root 13120 May 17 13:12 30_os-prober
-rwxr-xr-x 1 root root  1174 May 17 13:12 30_uefi-firmware
-rwxr-xr-x 1 root root   722 Jul 11 07:24 35_fwupd
-rwxr-xr-x 1 root root   214 May 17 13:12 40_custom
-rwxr-xr-x 1 root root   215 May 17 13:12 41_custom
sprunge.us ko ()
Please type
exit
at that grub prompt and relay what output it shows, here.
Does it work after using Boot Repair? When You go in BIOS, do You see in the Boot Order an ''ubuntu'' Entry? If yes, set it on first Position and try it again.
