When my keyboard battery is almost empty, I keep getting a popup saying my mouse is almost out of battery.
Not super annoying but is there a way to fix this?
Are you using Apple peripherals like me?
I have Magic keyboard and Magic Trackpad.
If it is a Bluetooth device, you can rename it in Blueman.
I'm using a logi keyboard for mac and a mouse with an old school battery, both plugged in trough usb
I wonder if there is any way to change the name of USB devices.
I will have a look.
[edit]
If you cable connect mouse and keyboard, you do not need batteries no? I am bit confused.
@HanneMaes Wat zijn de productnamen van uw muis en toetsenbord?
What is the product names of you mouse and keyboard?
They are wireless but I have to plug them in with a little USB.
My keyboard is a Logo MX keys and my mouse is a Trust.
The keyboard is recognised by the settings, the mouse not.
