Hello,
Can Zorin Ultimate be easily combined with Zorin Education ?
This looks like it could be a truly “Ultimate” Package.
But it would likely take a bit of work, I don’t think you could simple add one to the other ?
Thanks, BC
You can install all of the educational apps from the Education edition in Zorin OS Ultimate by running this command in the Terminal (which can be opened by pressing Ctrl+Alt+T):
sudo apt install zorin-os-education-preschool zorin-os-education-primary zorin-os-education-secondary zorin-os-education-tertiary
NICE !
Fast response
Thank you
