This is default installation, im not very pro in linux
This mean that is not in separate partition? And can i change and fix the problem with this or i will be back to the initial issue?
One note i test on pop_os and the not freeze and i can kill the game (if they are running and suspend or hibernate) what is the differences, Zorin use XFCE right, and pop_os gnome.
By the way if i use a layoute of a PRO version of zorin, this happen? (i mean ubuntu like, gnome etc...)
If it is a default installation, then you may not be using Hibernate. It does not come with it, that is something the user must set up.
Did you set up Hibernate? If not, what function are you referring to?
I really dont know, i search from some foruns, and they say that about swap.
But why this only happens in ubuntu or zorin, i test in pop-os, they freeze when gamming (probably nvidia drivers) but pop_os can kill the program without need to shutdow (hardpoweroff).
I dont understand why linux doesn't came with this "default".
I can resinstall Zorin (again ) and try to create this to test, but only need to create swap?
Let's focus on this, first. I do not believe that Swap is related to your problem. But we can explore creating a Swap Partition and setting up Hibernate if you want it, in a new thread.
For this one, please review here:
Please follow the steps outlined in that thread. There is a reasonable chance that the recent update with kernel 5.11.0-34 and your Nvidia are in conflict. This may have caused your current situation to revert, even as you had previously marked it as resolved.
I already boot into the recovery menu: Select the previous working 5.11.0-27 kernel Boot up Run software updater or run sudo apt dist-upgrade in terminal Once complete, reboot normally in the 5.11.0-34 kernel
Im lost know....do i run systemctl suspend or just close the lid? (remember that i have change the config to ignore)
