Hello.
I currently have ZorinOS 17.3 on my mid-2013 MacBook Air.
I installed it this morning. It is working great, no internet issues, but the Bluetooth is problematic. While it is detecting my earbuds, I have an error : br-connection-create-socket, and it is preventing me from connecting.
If anybody knows how to fix this, please help me
NOTE: Copy/pasted from Google AI...
The br-connection-create-socket error on Linux (including Zorin OS 18 / Ubuntu-based systems) usually indicates a failure to establish a socket connection for Bluetooth profiles, often caused by driver issues, power management bugs, or incorrect audio service configurations.
[image]Arch Linux Forums +3
Here are the solutions, ordered from most likely to least likely, based on recent reports.
- Disable Bluetooth USB Autosuspend (Most Likely Fix)
A known regression in Linux Kernel 6.14 (often used in Zorin 18) triggers this error by turning off the Bluetooth USB device.
[image]Reddit +1
- Open the terminal.
- Create or edit the configuration file:
bash
sudo nano /etc/modprobe.d/btusb.conf
- Add the following line to the file:
text
options btusb enable_autosuspend=0
- Save and exit (Ctrl+O, Enter, Ctrl+X).
- Apply the changes by updating the initramfs:
bash
sudo update-initramfs -u
- Reboot your computer.
Hello
I have tried your solution and other ones that Claude AI suggested; none of them worked. It concluded that it is a kernel problem, it could have compatibility issues with the Broadcom chip inside my computer. I already had to install special drivers for this chip, and apparently WiFi and Bluetooth interfere between each other in Linux.
Could You post the Output of the Terminal Command sudo lshw -C network please? And have You any Driver Options offered at the ''Additional Drivers'' Tab in Software & Updates?
It is in French, I am sorry :
*-network
description: Interface réseau sans fil
produit: BCM4360 802.11ac Wireless Network Adapter
fabricant: Broadcom Inc. and subsidiaries
identifiant matériel: 0
information bus: pci@0000:03:00.0
nom logique: wlp3s0
version: 03
numéro de série: b8:e8:56:09:a2:5c
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration : broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) ip=192.168.1.142 latency=0 multicast=yes wireless=IEEE 802.11
ressources : irq:18 mémoire:b0600000-b0607fff mémoire:b0400000-b05fffff
The only additionals driver are for this chip and I already use them; else I couldn't get WiFi
UPDATE
I have kind of solved this issue by spending 7$ on wired earbuds
