ZorinOS 17 l2tp/ipsec problem
After fresh install of Zorin 17 I can't connect to VPN using Network Manager. What are the packet names I should install? Method used on ZOrin 16 doesn't work.
l2tp/ipsec tunel established without any errors but no hosts are availble in remote network. DHCP works fine, routes are set and ip forwarding is enabled but I can't connect to remote hosts in target lan or internet.
