ZorinOS 18 wont wake up from sleep/suspend/lock
I’ve tried several things that I read about on the Internet, but nothing works for me. I don’t want to keep my PC on and my screen lit… Please, someone help me.
I’m new to this distro and haven’t had any problems with others.
Here are my settings:
So, You want that Your PC goes to sleep or You don't want that it goes to slepp but it does? I'm a bit confused because of the Thread Title and the Pictures You posted.
My computer don't wake-up. The picture is because a saw a lot of post that won to see it. I will remove it.
No need to remove them.
They may add to any clarity in the posts that discuss the issue as references.
Don't remove it. It is good to have such Stuff. I see, You have the Balanced Power Mode active. Try it with switching to Performance and see if it behaves different.
I just tried with Performance Mode and the same thing happened — my computer won't wake up from sleep :cry:. I tried with X11 and the monitor doesn't go to sleep mode... I hope this can be fixed.
