Zorinos virtualbox critical error occurred while the virtual machine
Hi, I wanted to work on virtual machines, but I have the following error:
A critical error occurred while the virtual machine was running and it was stopped.
You can get help using the forum at https://www.virtualbox.org (Community section) or by contacting us directly. Please remember to include the contents of the VBox.log log file and the VBox.png image file, which can be found in the /media/przemek/Pliki1/VirtualBox VMs/win102/Logs folder, as well as information about what was done immediately before the error occurred, in the description of the problem. You can also access the above files by selecting the Show log option from the Machine menu in the main VirualBox window.
Please press OK to turn off the machine or Ignore if it should be left intact for debugging. Note: debugging requires appropriate knowledge and tools, so it is recommended to press OK.
I tried restoring snapshots, creating completely new machines but I couldn't start them any further. I have virtualization turned on. The processor has 6 cores, 12 threads. I have 32 GB of ram
I used sudo apt-get install dkmssudo apt-get install --only-upgrade virtualbox
ls /lib/modules/$(uname -r)/kernel/virtualbox/
sudo apt-get remove virtualbox
sudo apt-get install virtualbox
sudo apt-get remove --purge virtualbox
Logs
I noticed no gap in the sudo elements on your previous post. I have looked at your log but I am no expert. You really need to post on the VB forum. It would help if you gave information on how many cores and RAM you allocated to the VM. When I used VB I would only use 2 cores and no more than 4 Gb RAM and would use .vhd images, never .vdi. My preferred VM software is virt-manager and you can import .vhd to become qcow2 images.
