Hello from germany,
I'm using a Thinkpad E595 (Ryzen 5 3500, VEGA, 32GB RAM, NVME) with ZorinOS 16.
When using battery mode at startup, ZOS is switching off Bluetooth and USB Ports after about 60 seconds (USB first, then after another 15 s BT) and doesn't turn it on when switching back to powered mode.. I even can't switch it on manually...
Settings in „ENERGY“ don‘t work, System doesn't remember the settings. BT-Off-Switch is "always on" when starting the system.
And still no USB-Port is working in battery mode after 60 seconds.
Double-checked litteraly all BIOS-Settings, but no chance to get the USB-Ports working...
This didn't happen in Win10 or LinuxMint which i was using before ZOS16. Everything works fine when using powered mode right from the start.
Any suggestions to solve this problem?
Regards Juergen
P.S.: Crosspost from r/zorinos subreddit
