Hi Aravisian, I tried the Zorin guys fix for Dell UEFI problem but having no luck so far. Maybe you can feed it back to them.
They note this:
- Navigate to General > Boot Sequence > Add Boot Option
- Select the "Boot Option Name" and insert "Zorin"
- Click on "..." in "File Name", select the Zorin OS Installation USB Drive and EFI / Boot / grubx64.efi
However, when I do this there is no grubx64.efi anywhere to be seen. The USB is recognised, along with the SSD, and I can select either one and have a look at different .efi files in different directories, including a Rufus one (I used this to flash the USB) but no mention of that particular grubx64.efi file.
I'm going to try Balena etcher to see if that makes a difference but the reason I used Rufus is, as you suggested, you can specify GPT and UEFI.
Secure Boot in BIOS is turned off by the way, as is Windows Fast Boot in Win 10 and I also disabled Hibernate in the registry just to make sure. POST Behaviour in BIOS is set to 'Thorough' as that's also recommended.
Edit: Should also say that I tried this, as suggested by Zorin guys:
"If the system can't identify the USB Drive at step 6, you can unplug & re-plug the USB drive to see if it changes inside the "File Name" > "..." menu."
