My camera not working after installing droidcam. I uninstalled droidcam and nothing happend. I can only turn on my camera by executing sudo modprobe
v4l2loopback. I tried add modprobe to /etc/modules but once it works and once it doesn't
Firefox can't use camera
And what is dummy device.
Maybe this helps: Droidcam Ubuntu 18.04 Error - Ask Ubuntu
droidcam worked
but my webcam not working
please help me
Firstly tell me that both cams are showing in sites
Like Google meet
Can you check that?
Mean option to choose cams!!
And i only have dummy device everywhere
wait, let me install droid cam and check it for you.
i had no problem after installing ....
can you send video or screen shot of google meet like this:
Okay, Did you uninstall all the software that needs to be used by droid cam?
IF not run this commands :-
sudo apt remove v4l2loopback-utils
sudo apt remove adb
sudo apt remove linux-headers-`uname -r` gcc make
ls -1 /dev/video*
And know which is dummy devices and delete it
/dev/video0
Is video0 is dummy cam?
yes
but after i if i use camera in firefox camera stopping working and if i enter in terminal
ls -1 /dev/video*
i have only
/dev/video0
is used v4l2-ctl --list-devices
and in output i have this
Dummy video device (0x0000) (platform:v4l2loopback-000):
/dev/video0
USB2.0 HD UVC WebCam: USB2.0 HD (usb-0000:00:14.0-7):
/dev/video1
/dev/video2
