Hi, I just installed Zorin os lite and I'm a complete beginner at this so please bear with me. When I first installed Zorin os lite there was already a problem with sound there was no sound, any help is appreciated
Ctrl+h to reveal hidden files (Files with a . in ront of the name).
If you have a ~.pulse-cookie file, delete it.
Then, navigate to /.config/pulse
Remove the /pulse folder.
Then
sudo apt update && sudo apt install -y pavucontrol
pulseaudio --kill
pulseaudio --start
I checked for a ~.pulse-cookie file there was none, then navigated to /.config/pulse removed the /pulse folder then on terminal:
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ sudo apt update && sudo apt install -y pavucontrol
[sudo] password for jeremiah:
Fetched 252 kB in 10s (26.4 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
pavucontrol is already the newest version (3.0-4).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ pulseaudio --kill
E: [pulseaudio] main.c: Failed to kill daemon: No such file or directory
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ pulseaudio --start
E: [pulseaudio] main.c: Daemon startup failed.
I remove the hit and get outputs because new users can only put 5 links
Is there any output to this command (checking permissions issues):
find $HOME ! -user $USER
What is the output of
uname -r
No output for find $HOME ! -user $USER
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ find $HOME ! -user $USER
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ uname -r
5.4.0-87-generic
It is not a permissions issue, then. Have you tried using Synaptic to install the signed 5.8 kernel?
Sorry for the late reply
What I'm doing is this correct? (Searching for 5.4.0-87-generic)
If it is what do I install?
Click Search on the top toolbar.
Enter into it linux-headers 5.8.0-63
In the treeview below, you should see listed linux-hwe-5.8-headers-5.8.0-63
Right click it and select Mark for installation.
Now, in the Search field again, enter in linux-modules 5.8.0-63
Scroll down toward the bottom and right click on linux-modules-5.8.0-63-generic and mark for install. Now, look below it for linux-modules-extra-5.8.0-63-generic and mark it as well.
Now linux-image 5.8.0-63 and mark to install on linux-image-5.8.0-63-generic
Click the Apply button on the top toolbar.
Once complete, reboot and test.
Try either linux-headers 5.8 or just linux-headers and see what it yields.
Synaptic was supposed to make this easier... But without me downloading a copy of Zorin OS 15 Lite o check all this, I think it may be harder.
Let's go with a direct and easy route: Terminal.
cd /tmp/
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8/amd64/linux-headers-5.8.0-050800_5.8.0-050800.202008022230_all.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8/amd64/linux-headers-5.8.0-050800-generic_5.8.0-050800.202008022230_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8/amd64/linux-image-unsigned-5.8.0-050800-generic_5.8.0-050800.202008022230_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8/amd64/linux-modules-5.8.0-050800-generic_5.8.0-050800.202008022230_amd64.deb
sudo dpkg -i *.deb
Oh, I see... you are using 32bit.
First, remove all files from /tmp
Then
cd /tmp/
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8.18/ppc64el/linux-headers-5.8.18-050818-generic_5.8.18-050818.202011011237_ppc64el.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8.18/ppc64el/linux-image-unsigned-5.8.18-050818-generic_5.8.18-050818.202011011237_ppc64el.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.8.18/ppc64el/linux-modules-5.8.18-050818-generic_5.8.18-050818.202011011237_ppc64el.deb
sudo dpkg -i *.deb
How to remove files from /tmp?
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ rm /tmp
rm: cannot remove '/tmp': Is a directory
cd /tmp
rm -r *
Is this a problem?
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ cd .tmp
bash: cd: .tmp: No such file or directory
I am sorry- I typoed. It is late here and my head keeps hitting the desk. I just corrected the post above...
It should be
cd /tmp
Oh ok
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:~/Desktop$ cd /tmp
jeremiah@jeremiah-Lenovo-ideapad-100S-11IBY:/tmp$ rm -r *
rm: descend into write-protected directory 'snap.chromium'?
What should I type?
You can hit the enter key. They are all temporary files.
That is why I took this route - since /tmp directory gets purged regularly. This way it is safe if you forget to clear out the downloads.
