I have a 1 TB SSd and a 8 TB hard drive that I have formatted to ext4 and created the partitions and have set it to auto mount though when I try to install steam games onto these drives I keep getting a 'disc write error.' Am I doing something wrong
In which package format is steam installed? When it is installed as flatpak you may need to set permissions with the app "flatseal" to grant access to your drive.
Or you can install steam as .deb package instead which has access to the files. You can use the steam-installer or download the package from the steam website.
How did You set up the Partitions?
