Auto-mount persistent SMB shares-revisit
Revisiting "Auto-mount persistent SMB shares" as it has been closed.
Zorin 64-bit OS 16.3
AMD® Ryzen 7 4700u with radeon graphics × 8
18G RAM
The reconnection of my SMB share has been working for over a year and no longer works. I changed nothing on the Zorin machine nor on the Windows share PC.
From the now-closed post above I tried several things:
  • I reran the command sudo apt install cifs-utils
  • I have a working shortcut in Gigolo but do not see how to get it to auto-run at startup. (Instructions say to enable an auto-connect flag but I see no way to do this.)
Most answers (and what eventually worked) have the fstab file and the smb.conf file setup for my environment but as I said, doesn't work anymore.
Below are the relevant fstab and smb.conf file lines, maybe someone can spot something?
Isn't there a way to add to the startup apps utility a command like:
smb://pcname.local/share/
Thanks all!
FSTAB:
UUID=ba1481b8-6324-4aaf-ace9-f44b3de1c096 / ext4 errors=remount-ro 0 1
#/boot/efi was on /dev/nvme0n1p1 during installation
UUID=9B4B-E346 /boot/efi vfat umask=0077 0 1
/swapfile none swap sw 0 0
//192.168.10.107/plexyd /home/richieg/samba cifs credentials=/home/richieg/.smbcredentials,uid=richieg,gid=richieg 0 0
SMB.CONF:
#======================= Global Settings =======================
[global]
##Browsing/Identification ###
Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = LOVEBIRDS
client min protocol = NT1
server min protocol = NT1
UPDATE
After being advised to change the last FSTAB line slightly to:
//192.168.1.244/servername /home/me/samba cifs credentials=/home/me/.smbcredentials,uid=rich,gid=rich,noauto,x-systemd.automount,_netdev 0 0 0 0
Now the share does automount but with 2 weird twists...
  1. I get 2 separate and identical SAMBA locations in my FILES' locations list,
  2. The new SAMBA locations seem to be very much slower connections than if I manually mount the same share via
    FILES > Other Locations > Connect to server > smb://server.local/share/
Thoughts?
Thank ya'll so much!
RichieG
I would also like to auto mount my smb share at startup. I can do it on my pi4.
I can manually mount using the terminal with the same command I use on the pi but the line I use in the fstab on the pi does not work on Zorin.
I've also succeeded at accessing the folders through the files app and bookmarking them. At least I only have to open files and click on the bookmark to get the "network servers" shortcut to appear on the desktop.
Note: The shared folder on the windows pc has a space in the name. On the pi "\040" is used for the space. Is that correct for Zorin?
Logon to network folder using files app
smb://MSI-I9-11-2.local/Shared Media/
Manual mount in terminal
sudo mount -t cifs -o username=name,password=password "//192.168.77.104/Shared Media" /mnt/Media
Auto mount in fstab (this one not working)
//192.168.77.104/Shared\040Media/ /mnt/Media cifs username=name,password=password 0 0
This two week old guide might help?:
I followed that guide and it still does not work.
I added the following to the fstab.
//192.168.77.104/Shared\040Media /mnt/Media cifs credentials=/root/.smbcredentials_auto,uid=1000,gid=1000 0 0
I seem to remember having a similar issue with the PI because it was trying to mount network shares before making the wifi connection.
I'm going to boot up the PI4 and have a look at the fstab there, maybe I had to add something. Nope, I see nothing there but I'm betting this is the issue.
I know there's a way to make the system wait for the wifi to connect during boot, but I forgot how. I'm going to create a new post for this question.
I notice a mix of forward and backward slashes ... shouldn't they all be one or the other?
"\040" represents the space in the windows folder name.
Don't know if this would work any better, but I suspect systemd causes more problems than it solves:
I got it working, differently.
It automounts the windows share when I open the folder, not when the system boots.
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda2 during installation
UUID=7e781b6e-de2e-45d4-96ca-74061209be9e /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/sda1 during installation
UUID=A415-20C6  /boot/efi       vfat    umask=0077      0       1
# Mount HDD
/dev/disk/by-uuid/d8e5dd52-ea9a-46da-85ba-2b981945bb1d /mnt/d8e5dd52-ea9a-46da-85ba-2b981945bb1d auto nosuid,nodev,nofail,x-gvfs-show 0 0
#Mount Shared Media
//192.168.77.104/Shared\040Media /mnt/Media cifs username=Name,password=pass,x-systemd.automount 0 0
