Battery Drain during suspend
Hello all,
My laptop drains 10-12% battery during a 7-8h suspend period.
Looking online, I was suggested to set suspend mode from s2idle to deep.
Strangely the battery drain during suspend is exactly same.
So my questions are
1] How to reduce battery drain during suspend?
2] Why changing s2idle-->deep had no effect
Thanks.
What device do you use and Can you run this command and share the response.
cat /sys/power/mem_sleep
Device name : Dell Vostro 3491
Specs: i3-1005G1
s2idle [deep]
If its still not working, then you can enable hibernation option using swap partition. here's how you can do that:
