Black screen problem after boot
Hello. I tried to install Zorin OS 18 Core. I downloaded the ISO file to a USB drive. I booted my computer from the USB and saw the screen with "Try" or "Install" options. I chose the first one. Zorin OS started, and there was a login screen. I selected "Live Session User," but then a black screen appeared on my monitor. I waited for 2–3 minutes, but it didn’t fix the problem, so I unplugged the computer and started my main operating system. How can I fix this black screen issue?
A couple Questions:
  • Did You checked the Checksum of the ISO?
  • What Tool did You used to create the bootable USB Stick with Zotin on it?
  • Are Secure Boot and Fast Boot on BIOS disabled?
  • If Windows is still installed: Is Fast Start-Up in Windows disabled?
  • Is Your BIOS in UEFI or Legacy Mode?
1 no
2 ventoy
3 no, they are enabled
4 yes
5 uefi
Here are Instructions:
Did You checked in the Ventoy Settings when You have created the USB Stick that it is set to GPT and not MBR?
Then, I would suggest to disabled them.
I had a lot of issues with black screen when installing 17.3 Pro in dual boot with Win 11.
This link from a post from @Forpli was what solved it for me.
One word of caution: while acpi=off worked to get me past this issue, it later caused a different problem with getting my ethernet card and sound card to work so @Aravisian had me use acpi=noirq instead
One other thought to add to your list. He may have RAID set in his BIOS from windows that needs to change to AHCI. I made the change in windows safe mode without any negative outcomes.
Good Point.
