i just installed Zorin 8.1 but when i try to turn on the Bluetooth wont and turns off (wont stay on)
- Are Secure Boot and Fast Boot in BIOS disabled?
- If Windows is still installed: Is Fast Start-Up in Windows disabled?
- Did You checked the ''Additional Drivers'' Tab in Software & Updates if there is a Driver offered?
- What Kernel is in Usage? You can check that with the Command
uname -rvia Terminal - Does Your System run in Wayland or X11? You can check that with the Terminal Command
echo $XDG_SESSION_TYPE - Is it built-in Bluetooth or a Dongle?
- Could You post the Output of
rfkill listplease?
If you are dual-booting, I discovered that Windows grabs the bluetooth connection and sometimes they only way to get this to work in GNU/Linux is to copy the bluetooth key from Windows and insert it in GNU/Linux, but no guarantees.
Do you have Bluez and Bluman installed?
If the device is greater than Bluetooth 4, then you may need some additional packages using Synaptic Package Manager - see the screenshots in my Tutorial here:
Also, what adapter are you using? Built-in or USB? I have had issues with certain USB adapters that exhibited this behaviour: would initially turn on but then turn off and disappear. The only reliable Bluetooth adapters for Zorin I have found so far are TP Link.
