Can I haz - Single click to open desktop shortcuts?
I already have single click to open selected in the file manager.
I want the shortcuts on the desktop to work the same way.
Is this possible? If yes how?
I don't know if this is helpful
You can scroll down for more options
Har lige prøvet det, virker ikke :unamused:
@jerik
That was indeed helpful.
I installed Nemo (file manager) and I like the way it looks and works better then the default file manager. I have single click on in there and I've now learned, it works only in there
I've also learned through things like this that I now have 2 files managers installed and each controls different things.
I had to open the file manager that is not set as defult and turn on single click in there. Apparently it still controls the desktop.
That is due to Gnome's inherited Windows theology of "We control everything, you control nothing; we make the desktop how it should be, not what you want it to be." That is why I am a Plasma user and not a Gnome user. (And Zorin is not my daily driver anymore.)
