Hello, so i was using Zorin for a while now and everything was just fine, but today my internet went down on one of its points
I have two, so lets call them point A (which can be accessed through wi-fi) and point B (which can be accessed through ethernet and wi-fi)
So, internet went down on point B (apparently a bug on the LAN routing, after changing it from 192.168.0.1 to 192.168.1.1 and then to 192.168.0.1 again solved it) and i used wi-fi on point A;
So when i fixed the problem on point B, i tried using it on my Zorin (it is working ATM on my phone, some windows machines, smart tvs etc) but it didn't connected to it. I couldn't connect it to in any way!
On the wired connections pannel it shows that it is trying to connect - but then shows the cable is disconnected right after; on the wi-fi pannel it tries to connect, but never does. It loads forever!
So, i tried restaring my pc, device, wifi-router, tried a bunch of commands i found online (will post it below)
I tried to force Zorin to forget the wi-fi connection and try to connect to it again, but no luck
Well if it helps anything, here are some commands i tried:
sudo service network-manager restart (did restart my network but even so, point B is unreacheable)
Tried editing etc/network/interfaces but it is empty
Please help me
Here is the output of my ifconfig command:
enp59s0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 fe80::a5e2:1b05:a290:df07 prefixlen 64 scopeid 0x20<link>
ether 54:bf:64:25:3c:0b txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 22 bytes 7590 (7.5 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 17
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Loopback Local)
RX packets 8178 bytes 855562 (855.5 KB)
TX packets 8178 bytes 855562 (855.5 KB)
wlp60s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.108 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::82e6:ea2a:9f4d:bd50 prefixlen 64 scopeid 0x20<link>
ether 74:40:bb:f3:79:73 txqueuelen 1000 (Ethernet)
RX packets 31765 bytes 26447351 (26.4 MB)
TX packets 25493 bytes 4784087 (4.7 MB)
