Okay, so the noob in me is in full force today. I'm trying to copy some files onto my external drive, but it won't allow me. Yes, I've checked the permissions which say I have full write privileges, but I can't create a new folder in it, and I also can't copy a folder to it.
In terminal I get this error: cp: -r not specified I can't find the answer on google. Can someone here explain, please?
Media is a mounted file. It may have mounted in read-only state. It is supposed to mount as r/w by default... Have you tried unmounting and remounting it?
This guide may help (Ignore ntfs and the commented portions. Change the example /dev/sdb1 to be your actual drive directory):
If that is not working, you may need to check your fstab.
This is so very over my head. I just don't understand why I cannot simply plug in my external drive and use it like I do my flash usbs?
Why do I have to go through all this coding messing with my partitions? I don't want to risk that... especially after yesterday and nearly losing my entire computer to a "simple" bug fix.
I have zero clue what I'm doing here. Things that should just be simple in Linux, are not.
I feel your pain because... I don't just mean it should do that... I mean that in Linux, as it is, it is supposed to do that. It is coded to do that.
I have an external HDD, as well. I plug it in and I have read and write permissions. I copy files back and forth all the time. It works by plugging it in.
Something in your case isn't.
You might try using the terminal to just double check that permissions are granted. The terminal never misses even though a GUI app can. Fill in the blank...:
sudo chmod 777 /media/____
If the external is formatted to ntfs (The nt file system is exclusive to Windows Only), Linux can read it, not sure if it can write or not... What format is the external drive?
But my understanding from researching pre linux install was that I could use external drives as the go-between for my dual boot. No matter how much I dislike Windows, I am unable to ditch it because of work. But I'm trying to do as much of my work here on Linux as possible.
As a side note: I do have access to my Windows install in the folders here and can copy and add files (just not delete/move files) so I'd imagine it would be no different for an external drive, no?
Yeah, I'm just having a rough go of getting things to work for me in Linux. I have no idea why. I realise my computer is "too new" and high-end for Linux's software. But the basics are what are killing me. If it weren't for you helping me all the time, I'd have ditched Linux days ago.
I have experienced this exact issue as well. I remember not finding any solution to it. But, a clean re-install solved the problem and I have not encountered it ever since.
Oh god... a reinstall? Well with the issues I'm having with my graphics card, bluetooth, sound, and now the external hd... I'm thinking you may be right...
Yeah don't worry about it. On my first Zorin install I was also a bit careless with how I handled my system but from that point onwards, I took more care of my system to ensure its nice, clean, and smooth.
I haven't been careless. It's that I have a very high-end computer that seems to disagree with Linux in many ways. Gah! It's a struggle to get everything working correctly. This is the 3rd distro I've tried in 2 weeks. Really want to make it work.
Just did a fresh install and still, the external hd issue remains.
