Hi,
My printer is installed from USB, but can't print. Someone times, after shutdown the computer, the print is made.
I tryed HPLIP and Sane.
When I use "hp-setup" from terminal, the message is showed:
error: Device busy: hpfax:/usb/Deskjet_4640_series?serial=CN54P6B0Y005Z4
error: Unable to communicate with the device. Please check the device and try again.
Via WiFi, I can install and the print works fine.
Regards,
Marcelo Costa
Porto Alegre - Brazil
Can you please run hp-check -i in terminal and post the output here using pastebin ?
Hello Aravisian,
The pastebin output:
https://pastebin.com/embed_js/mawERSWL
Thanks,
Marcelo
I think we saw this problem in the forum before.
The final conclusion was to use WiFi because no one came up with the solution.
You are the second person who found that USB connection does not work for the printer. Only WiFi connection works.
@Aravisian , we should consider this WiFi connection when people having a trouble with their printer.
CUPS was already installed and running.
https://pastebin.com/embed_js/CzyvgvDp
Yes, WiFi can be a solution, but on others scenarios, the WiFi connection cannot be available.
Thanks,
Marcelo
warning: HPLIP-Installation: Auto installation is not supported for unknown distro 16 version
It appears that the installer is looking for Ubuntu and not Zorin. Due to this, it failed to install necessary dependencies.
Can you please try
sudo apt remove --purge hplip
sudo add-apt-repository ppa:kelebek333/hplip
sudo apt install hplip hplip-plugin
system
Closed
February 9, 2022, 12:54am
9
