Hello !
I have a problem. When I press Maj (CapsLock), the numbers don't appear. Instead, I have &É"'(-È_ÇÀ)=
Is there a way to obtain 1234567890°+ ?
Thank you !
Hello !
Thank you !
The Numbers should be the default Output when pressing them. What for a Keyboard do You have (Brand/Model)? Is it a 60, 65,75, TKL or 100 Percent Layout? What Keyboard Language is set up and What Language Layout Format?
Hi, and welcome to Zorin OS!
This seems to be a known issue with certain keyboard layouts, although it's not clear whether this is specific to Gnome or not.
It can be reproduced easily by using one of those language inputs:
I've tried following the solution described in the following page below, but without luck. Maybe it will work for you:
Are you entering numbers using number pad, or second row of your keyboard?
