I've been testing Zorin 18, and I've loved it. However, when I installed Citrix, it caused incompatibility with the desktop style. Has anyone managed to solve this problem?
Forpli
November 1, 2025, 11:54am
2
Here is a site that may help. I haven't used this program yet.
I had the same issue.
Zorin OS 18 Core
Citrix Workspace 25.08.10.111
Two ways I found to address it:
Removing the Citrix Workspace App
sudo apt-get purge --auto-remove icaclient
Remove the App (see 1.)
2a. Reinstall & make sure to choose No for the App Protection Component
found this solution here: Zorin Core 17 - Layout ignored - #9 by zenzen
This seems to have popped up before:
There is issue with ZorinOS core and the ICAclient of Citrix. The moment I install the ICAclient and reboot the system, the entire appearance of Zorin changes. Whether I use the ICAclient at a remote workplace or not. The problem already occurs if you have installed the ICAclient. Even if I use "sudo apt reinstall zorin-appearance zorin-appearance-layouts-shell-core zorin-appearance-layouts-support" it doesn´t bring back the appearence. After I deleted the ICAclient, Zorin looks the way I want i…
You could try a Reinstall. To do that, open the Terminal and type:
I had the same problem. When I deleted the ICAclient again the appearance loaded as normal again.
I hope you can fix this issue.
I also openend a topic about this issue but found at the end this topic
system
Closed
April 29, 2026, 10:15pm
4
