Cross Platform File Sharing on Home Network Help Please...network with Windows computers and need help
Hello,
Could someone please provide some guidance on sharing files between our Desktop computer with Zorin 18 OS and our laptops with Windows 10/11, on our Home Network?
I am desiring to use our LAN Desktop computer with Zorin OS, as a backup computer for our WIFI Windows laptops.
I typically used EaseUS ToDo Backup to synchronize files/folders and I desire something similar for the cross platform.
I installed LocalSend file sharing software on the Zorin computer and our Windows computers and it works perfectly, with one major exception. You cannot choose where to save the files to, from the Windows computers. You can only choose where to save the files on the Zorin machine. So, documents and picture files get saved to the same location and I need the ability to choose where to save the files from the Windows computers. Otherwise, I'd have to transfer the files from the Windows machine to the Zorin machine, and then go to the Zorin machine and manually move the files to the proper folders. That is not a proper or practical backup solution.
Thanks,
Ralph
A network shared folder could let you keep choosing the backup destination from Windows, if your installed EaseUS version supports it. EaseUS documents shared folders as destinations under its NAS option, and its Free changelog also lists NAS support for file backups. On Zorin, this would require a password-protected network share rather than open guest access, with separate destination folders for each laptop's backups. I haven't verified the sharing setup for Zorin 18, so this is a possible approach rather than a complete setup guide.
Hello and welcome,
For cross platform share you can use Samba
Install Samba
Update your system
Update your system before installing Samba. Run below command to update your system.
sudo apt update && sudo apt upgrade -y
Install Samba
To install Samba, use the following command.
sudo apt install samba cifs-utils -y
Configure Samba
Samba’s configuration file is located in /etc/samba/smb.conf. You can customize it by editing this file.
Edit configuration file
Edit Samba configuration file and add the lines given in next step.
sudo nano /etc/samba/smb.conf
2. Setup shared directory
Add the following section at the end of the file and save your configuration file.
[SharedFolder]
path = /path/to/shared/folder
browseable = yes
writable = yes
guest ok = no
read only = no
Replace /path/to/shared/folder with the folder path you want to share.
Note: If you have made any changes to the configuration file, you have to restart Samba service.
Create a Shared directory
If the given folder in the configuration file doesn’t exist, you have to create it and want to apply proper permissions.
 mkdir -p /path/to/shared/folder
 chmod -R 775 /path/to/shared/folder
Start and Enable Samba service
Restart Samba
Once the changes are made, restart samba using the following command.
sudo systemctl restart smbd
Enable Samba to start on Reboot
sudo systemctl enable smbd
Check Samba Status
sudo systemctl status smbd
You can after install Nautilus Share to share a folder with right click in file manager
sudo apt install nautilus-share
May not be exactly what you are looking for but I have used Spideroak as my back up and synching solution for the past 10 - 15 years and it works just fine with Linux and Windows machines. However, I also set up NFS local file sharing to use my desktop Zorin computer as file server accessible from my Zorin surface computer and my wife's remaining windows laptop that I just haven't yet gotten around to converting to Zorin. For NFS this tutorial from @zenzen made all the difference after failing using tutorials from other internet sources that were defective.[HOW TO] Share folders over the network using NFS
I use syncthing for my document files and folders that are in constant use and freefilesync for media and folders that are seldom used.
I have 3 pc with zorin 18.1 core only on them but I believe these two apps are cross platform.
Thanks for all of the replies thus far.
