You have to split Things here: Ubuntu and Ubuntu Pro. You get Security Updates - all that You need. The Ubuntu Pro thing is only for an extended Support. And to say that: You shouldn't use Pro on Zorin. When You use Ubuntu directly, You can make that - but only there.
So, yes. It might look confusing. But You get Updates normally on Zorin, too.
just for clarification, i dont want to open a discussion on ubunto pro, my post is showing how to investigate if a machine is patched or not, nothing more.
Ubunto-pro can be an option for long term use and is free for private. If you follow Zorins major relaeses you are done, no additional setup neccessary, no need for pro.
Regards
There is for sure room for add communication, as always in life. On the other side we have be calm while media are hyping these issues (and earning extra money). All these issues need a local user to generate the scrap, so its about us. Thats why I personal do not see this so critical as hyped in a lot of media.
Security patches are delivered with regular Zorin updates and if you follow the major releases yor are setup well. No need to change the distro or going for pro.
I am thankfull of the Zorin Team - they are doing a great job
The Hitchhiker's Guide to the Galaxy teached us "stay calm"
How, step by step, can I find if I have the update already installed?
I am applying every update that is arriving to my Zorin OS 18.1 installation, but I am not sure if that one was already offered to me in the last few days.
Look in your file manager if you have that file at /etc/modprobe.d/disable-algif_aead.conf
You can enter the path in the top bar of your file manager or go to other places / filesystem on the left side and then click through the folders: etc > modprobe.d
The update for that fix was two weeks ago. So first look if you have the file.
