I applied this lesson to no avail
My problem is the same, I am trying to understand and apply
You know that I use a compiler, and I can understand the theories clearly only through practical applications, and that is step by step, for example, distinguishing the basic disk from the logical one or converting it, and to avoid this problem, just diagnose the problem, mention it, and let me find the solution
I looked at the section and found it as I wanted
I cannot do without one of the four main sections that contain Windows and my things, I am afraid that the mentioned section will be important when I try to repair Windows
This option is not available to me
When the problem is over, I will report, please help everyone as much as possible
