vamp
September 5, 2023, 8:24am
1
Hello there,
I get connection failed error message lot of time. I notice that cause that USB ethernet adapter are enabled, but not connected. I try to disable/remove it, but it connect/recreate it every restart.
My PC: HP-EliteBook-840-G3
My problem are similar with this topic:
Hello,
I've had Zorin OS for many months on an HP EliteBook 1040 G3.
Since installation, it all works including Wi-Fi 99.5% of the time.
However, I get random but constant "Network Activation Failed" errors, which sometimes cause websites to fail with a "Your connection was interrupted" browser error.
It seems the wifi chip is an Intel® Dual Band Wireless-AC 8260.
I have already turned USB Ethernet off.
[Screenshot from 2023-05-27 15-27-49]
I also did what was suggested in other similar p…
It possible to turn off this adapter somehow?
Yes, you could blacklist it.
Can you post the output for
sudo lshw -C network
Remember to beware the X-Y problem. You could blacklist the driver but it may be that the driver only needs to be repaired.
vamp
September 5, 2023, 2:13pm
3
*-network
product: Wireless 8260
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: wlp2s0
version: 3a
serial: f8:63:3f:67:63:cb
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.15.0-83-generic firmware=36.77d01142.0 8000C-36.ucode ip=172.16.2.2 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:130 memory:e1100000-e1101fff
*-network
product: Ethernet Connection I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 21
serial: 30:e1:71:87:01:12
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.15.0-83-generic firmware=0.13-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:125 memory:e1200000-e121ffff
*-network
physical id: 2
bus info: usb@1:3
logical name: enxae6bb296dd80
serial: ae:6b:b2:96:dd:80
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=cdc_ether driverversion=5.15.0-83-generic duplex=half firmware=CDC Ethernet Device link=yes multicast=yes port=twisted pair
vamp:
I219-LM
I see two ethernet devices here, with two different drivers.
Is one a Plug n' play card?
vamp
September 5, 2023, 2:23pm
5
I not use any USB ethernet. Only integrated pci and wifi.
In terminal, elevtate to Root
sudo -i
Launch your file manager from that elevated terminal
nautilus
Navigate to "Other locations" > "computer" then /etc/modprobe.d/blacklist.conf
You can open blacklist.conf
by right click > Open with > Text Editor (Gedit)
Add these two lines to the bottom,
blacklist e1000e
blacklist cdc_ether
Save the file and close it. Close Nautilus (Files) File manager.
In terminal, type
exit
Now, run
sudo update-initramfs -u
Reboot to test.
vamp
September 5, 2023, 7:14pm
7
thanks, i will tested it tomorrow, when i nearby my notebook.
system
Closed
December 4, 2023, 7:14pm
8
