Hi, I have a problem with what seems to be a feature, and I'd like to disable it.
When I use multiple windows (terminal windows for example), when a window loses focus it dims, making it difficult to read text. I use multiple monitors, and I'd like to be able to read text from multiple windows at the same time without straining my eyes. Is there a way to disable this dim-on-lost-focus feature?
I believe that the effect you are describing is based on the Zorin Theme you are using. Changing to a theme that does not dim inactive windows may work.
Otherwise, we may need to assist you in setting up a custom gtk.css file in ~/.config/gtk-3.0/
You can set the window:backdrop property to use the same background color and text color as the active window.
For example, in Zorin-Blue-Light theme, the active window is:
Im very intrested because will disabling dimming also disable dimming of the system title bar? I remember in KDE there is a toggle to disable dimming of the window but you can leave the title bar dimmed when losing focus vice versa, you can even disable dimming.
Since i'm spoiled by KDE's settings I don't know I can help much but I can try I guess.
I just tested this twice, with different variables. Then tested it on a copy of "Try Zorin".
It worked each time... I am not sure what is causing it not to on yours...
I wonder if you are testing it in a Flatpak application that is referencing the Flatpak Zorin themes- that is the only thing I can think of that may interfere.
Theme. I tested it... Plus I recall another member had the same question about a month and a half ago and we performed the same solution, successfully, then.
The gtk.css file placed in ~/.config/gtk-3.0 gets First Priority.
Then, the gtk.css file placed in either ~/.themes or ~/.local/share/themes gets next priority.
That is partly why I prefer edits to be made to ~/.config/gtk-3.0/gtk.css while the other reason is because edits are more easily altered or undone in ~/.config/gtk-3.0/gtk.css than they are in the Main Theme. What if you do not remember the Original parameters of the Original Theme, but it is already changed and saved?
ctrl+F, then search for everything that has the property :backdrop
Compare the backdrop items to the non-backdrop and you can recolor all :backdrop'ed properties to match the class that is not backdropped.
(Be wary that not all items that have a backdrop property should be changed. Read what you are changing. Use the back-up copy to restore mistakes).
The system was freshly installed about a week ago, and wasn't customised at all (except for the changed theme to dark in Zorin Appearance app). Is there any other information I can provide?
