hi, i downloaded zorin 18 core and am having issues with display color scheme my screen is built in because am using a laptop and i dont know to manage the colors like changing the contrast or rgb levels is there a way to change them in windows there was an app for intel gpu software from there i was able to change the colors how i can do the same for zorin?
Hi and welcome.
Have you looked inside Settings and Color Profiles? Not sure if that is what you need and to be honest I have never used it, but I think that might be where you need to start.
Don't forget to download the Unofficial Manual that I wrote for 18:
Hi and welcome to the Forum.
I assume from that you have an Intel graphics card.
On ZorinOS, screen brightness should be adjustable from the Taskbar, but not Contrast or individual colours.
What issue do you have with screen contrast and/or colours?
Are you using Wayland (default) or X11?
You can check that with the Terminal Command
echo $XDG_SESSION_TYPE
If you see Wayland, you could try X11 to see if any difference.
To switch to X11 (or Xorg), go to the Login Screen. Click your Login Profile to reveal the Password Field, but do not login yet. Find a gearwheel or cog icon bottom right of screen. Click that and choose the Option ''Zorin Desktop on Xorg''. Then login as normal.
This thread may also be worth a read: Color Calibration help
Also : How to calibrate the color and contrast in my laptop display
it worked thanks! i went to the x11 and i found an display gamma app from there i changed the gamma then i went to zorin again and everything is now perfect thanks again and i guess am staying at zorin forever!
thanks to zabadabadoo i solved my problem but i will take a look into that so thanks to you to!
